制作工作分解结构 [发表于 2003/12/27] 状态 开放帖 浏览量 3193 |
Re:制作工作分解结构
[回复于 2004/1/29]
WBS考虑的是PROJECT'S PRODUCT OR SERVICE的分解....
9楼
rickluxe
发帖 683篇
注册 2003/8/1
PM币 2285
Re:制作工作分解结构
[回复于 2004/1/29]
Work Breakdown Structure This term is defined as: A product-oriented family tree composed of hardware, software, services, data, and facilities. The family tree results from systems engineering efforts during the acquisition of a defense materiel item. A WBS displays and defines the product, or products, to be developed and/or produced. It relates the elements of work to be accomplished to each other and to the end product. A WBS can be expressed down to any level of interest. However the top three levels are as far as any program or contract need go unless the items identified are high cost or high risk. Then, and only then, is it important to take the work breakdown structure to a lower level of definition
10楼
rickluxe
发帖 683篇
注册 2003/8/1
PM币 2285
Re:制作工作分解结构
[回复于 2004/1/31]
好象就是常说的5W方法吧:既WHAT ,WHERE ,WHEN,WHO,WHY
11楼
aming934
注册 2004/1/31
PM币 101
Re:制作工作分解结构
[回复于 2004/2/1]
楼上说的不对喽...看看camer和毛肚说的....
-------------------------------------------------------------------------------------------------------- 让生活如涓涓细流,欢快,轻盈,歌唱着一路欢腾下去... 让工作成为我生活的图腾... MSN:ruddyli@hotmail.com
12楼
ruddyli
发帖 1764篇
注册 2003/8/28
PM币 10623
Re:制作工作分解结构
[回复于 2004/2/10]
WBS 顾名思义是 work breakdown structure
-------------------------------------------------------------------------------------------------------- 项目管理是变化的管理! http://www.mypm.net/bbs/nboard.asp?ntypeid=5006 请支持我的板块 MSN: uppaladin@msn.com QQ:26184936 QQ群:4087658
13楼
coolmonk
发帖 257篇
注册 2004/2/3
PM币 1946
Re:制作工作分解结构
[回复于 2009/5/15]
但是WBS的目的不就是实现C/T等精准控制码?
14楼
liangwb3
发帖 151篇
注册 2009/2/25
Re:制作工作分解结构
[回复于 2009/7/11]
感谢大大无私的分享。
15楼
chennick
来自 香港
发帖 164篇
注册 2008/11/15
PM币 133
Re:制作工作分解结构
[回复于 2010/3/11]
好像不是。
16楼
xinghua0212
发帖 197篇
注册 2010/3/11
