精彩专题 |
| 更多:
联系社区管理员 |
What should be a top 10 concern for CIOs? [发表于 2003/10/10] 状态 开放帖 浏览量 2045 |
IdeaByte ♦ CIOs’ Issues for 2002: Project Management RIB-112001-00136 © 2001 Giga Information Group All rights reserved. Reproduction or redistribution in any form without the prior permission of Giga Information Group is expressly prohibited. This information is provided on an “as is” basis and without express or implied warranties. Although this information is believed to be accurate at the time of publication, Giga Information Group cannot and does not warrant the accuracy, completeness or suitability of this information or that the information is correct. © 2001 Giga Information Group Copyright and Material Usage Guidelines November 16, 2001 CIOs’ Issues for 2002: Project Management Margo Visitacion Catalyst Analyst collaboration Question What should be a top 10 concern for CIOs? Answer Project management rarely gets mentioned as a top 10 concern for CIOs, but it should be. When speaking with CIOs about critical issues, project management often comes up. Organizations are increasingly determining and meeting their objectives through initiatives, whether it is product delivery, cost-saving programs, etc. Each of these objectives translates into programs, consisting of multiple projects. Successful delivery requires repeatable practices shared across projects, just as resources are shared across projects. Justifying formal project management practices is becoming easier; acceptance is growing and implementations are working as demonstrated in the latest CHAOS figures — successful (on time, on budget) projects grew to 28 percent from 16 percent in the first study in 1994. The percentages look small, but factor in the number of projects surveyed tripled from the first study to the latest. Portfolio management is another area where formal project practices brings value because companies adept at managing portfolios are adept at meeting objectives. The key components in portfolios are investments, and investments are executed projects. Companies can choose the right investments but unless you can execute, it doesn’t matter how well you plan. Develop some standardization, performed with flexibility, for project management. While this requires concerted effort, sustained practices result in increased project delivery. Giga recommends the following: •= Put repeatable practices in place by standardizing phases, hand-offs and implementations. These are standard exercises in most projects, and often are the areas where the most errors occur. •= Concentrate on the soft stuff — let project managers be creative with the process to maximize talent and gain team commitment. Give them guidelines but don’t force them to use the standard project management jargon. •= Support them. As redundant as it sounds, executive support is critical. There is much to be said for top-down support, but consider starting at midlevel and spread from there. Midlevel management is closer to organizational pain to develop corrective practices. •= Invest in tools but don’t go crazy — it pays to start smaller. Go with a pilot project, but don’t manage in a vacuum. Continually look for ways to implement out into the organization incrementally. •= Invest in talent — downsizing has released a large number of talented project managers into the available market. Recruit strong talent and train existing talent to build internal processes collectively.
howard_hong
发帖 1036篇
注册 2003/6/6
PM币 3684
Re:What should be a top 10 concern for CIOs?
[回复于 2003/10/10]
提交发送时出错,所以就出现了3个,并非灌水!
howard_hong
发帖 1036篇
注册 2003/6/6
PM币 3684
