Project Planning [发表于 2003/9/5]
状态 开放帖 浏览量 1280
Starting a project with a good plan is like mapping out the course your project will take. A good plan tells you which direction to go, what turns to take, and what to do if you run into a bump that causes you to take a detour.
Regardless of the size, type or duration of a project, a good plan will guide you from beginning to end and it will help increase the likehood that your project will be successfully managed and completed.
楼主 帅哥约,不在线,有人找我吗?快乐虫子
发帖 45篇
注册 2003/8/30
PM币 190
经验 23点
Re:Project Planning [回复于 2003/9/8]
Where did you copy these words from?
It's sounds reasonable but with no meaning.
Anyway, these are good saying. Hope to see more topic on Project planning. Infect, only few people konws professional project planning in China at the moment.
1楼 帅哥约,不在线,有人找我吗?l000
发帖 84篇
注册 2003/3/10
PM币 6262
经验 140点
Re:Project Planning [回复于 2003/9/18]
I agree with you, but how to plan ? this is difficulty for me to think
從零開始, 有夢想就有希望
2楼 美女约,不在线,有人找我吗?karen2003
发帖 22篇
注册 2003/9/16
PM币 154
