Project Planning  Overview 4 [发表于 2003/9/5]
状态 开放帖 浏览量 2047
Project planning is the critical aspect of any project. With continuous advancements and time demands in today's business world, there may be a temptation to get started on a project without considering where it will lead. The greatest danger in doing this is misunderstandings between stakeholders, which arise from diffrences in expectations. Planning helps you to form ideas and to discover where the project needs to go and the best way to get there in the allotted time.
楼主 帅哥约,不在线,有人找我吗?快乐虫子
发帖 45篇
注册 2003/8/30
PM币 190
经验 23点
Re:Project Planning Overview 4 [回复于 2003/9/8]
Evenif good planning is helping you within project execution, still there are many things out of control, why?
Planning is a thinking way, instead of a method or technology.
You are thinking in this way so you trust it; you trust it so it can help you.
Planning is not for teaching, it's for applying.
1楼 帅哥约,不在线,有人找我吗?l000
发帖 84篇
注册 2003/3/10
PM币 6262
经验 140点
You are right. Plan is not important, the most important thing is the process of plan defination and modification.
This training material is provided by one famous training Org. I just wanna share it with buddies step by step. Hope it's helpful.
2楼 帅哥约,不在线,有人找我吗?快乐虫子
发帖 45篇
注册 2003/8/30
PM币 190
经验 23点
Re:Project Planning Overview 4 [回复于 2007/1/31]
谢谢楼主,辛苦了。
自主创新,振兴中华
3楼 帅哥约,不在线,有人找我吗?chenniangen
发帖 7篇
注册 2006/8/7
PM币 35
经验 17点
