Project Planning --Scope Planning [发表于 2003/9/5]
状态 开放帖 浏览量 1201
Planning the project scope is the first step once a project has been assigned, and it it the point where you lay the foudation for all the work yet to come. The scope plan is the map that team members use to guide them through the project, from start to finish. Therefore, if it is not properly developed ir carried out, the project may fo drastically wrong.
A properly planned project scope is beneficial to you, as a project manager, to your team members, and to your company. By learning how to plan the scope of a project, you will understand what is required to develop an appropriate and realistic scope that you will be able to manage effectively throughout the life of the project. With your project scope in hand, you will then be able to create a scope statement that will effectively outline your project and enable you to strike a blanance between maximizing profit and minimizing risk.
楼主 帅哥约,不在线,有人找我吗?快乐虫子
发帖 45篇
注册 2003/8/30
PM币 190
经验 23点
Re:Project Planning --Scope Planning [回复于 2003/9/8]
So comes WBS which is well know but only few people knows how to use it.
1楼 帅哥约,不在线,有人找我吗?l000
发帖 84篇
注册 2003/3/10
PM币 6262
经验 140点
这几天工作太忙了,培训教材无法复制,偶只能自己录入。关于WBS的问题,我还有些不成熟的想法,过几天想清楚了与大家分享。
另外,我们中那位能不能谈谈对Critical Path管理的经验? 我觉得做项目管理应该时刻注意这个问题。
2楼 帅哥约,不在线,有人找我吗?快乐虫子
发帖 45篇
注册 2003/8/30
PM币 190
经验 23点
Re:Project Planning --Scope Planning [回复于 2003/9/9]
有道理,我也很关注Critical Path的建立和管理,谁有相关的经验,或模版或某项目作品...统统分享一下:))
让生活如涓涓细流,欢快,轻盈,歌唱着一路欢腾下去...
让工作成为我生活的图腾...
MSN:ruddyli@hotmail.com
3楼 美女约,不在线,有人找我吗?ruddyli
发帖 1764篇
注册 2003/8/28
PM币 10623
经验 2976点
Re:Project Planning --Scope Planning [回复于 2003/9/15]
About Scope management, PMI Practice Standard is a good reference.
Qiao Dong PMP
4楼 帅哥约,不在线,有人找我吗?qiaodong
发帖 1363篇
注册 2003/2/18
PM币 4342
经验 2003点
No WBS is available for all projects,but a adaptive WBS is for your project.
5楼 帅哥约,不在线,有人找我吗?changpl
注册 2003/8/26
PM币 108
