项目管理软件之planbee [发表于 2004/1/13]
状态 开放帖 浏览量 1411
无意出发现了这个项目计划软件,因为不知道如何贴图.只能将一些简介放在这了. 其实,项目管理工作可以用软件作辅助的.
Project Management with PlanBee:
Calculates Early Start, Late Start, Early Finish, Late Finish, Float (Slack) and identifies Critical Path activities.
Shows all project management data in a "spreadsheet" pattern for ease of understanding.
Task data may be entered manually or imported from a file or the clipboard.
Independent re-sizeable and hideable windows show PERT views and Gantt (bar chart) views of the project in addition to the "spreadsheet" view.
Activities and links may be set up and edited in either spreadsheet or PERT views or both at once, since all views are kept synchronized.
Network file sharing permits other users on a network to have read-only access to a plan file while one user has it open for exclusive update. They may modify it and save it to a different file name if they wish.
Up to 1,000 activities with up to three levels of sub-project or departmental grouping.
No limit on links per activity (within total of 2,000 links).
Links may be Finish-to-Start, Start-to-Start or Finish-to-Finish to handle overlapping activities.
Links may have minimum time lags specified.
Individual activities may have their dates "fixed".
Pop up "working day" calendar with 200 year range. Easy to change working/non-working days.
Activity durations and lags may be specified as either "working days" or "calendar days" - both types may be used in the same plan.
Scale of PERT and Gantt charts are adjustable both on-screen and for printing (to make best use of pages).
Reports, PERT charts and Gantt charts may be either printed, or copied to the clipboard for pasting into other programs.
PlanBee Pro adds features for large plans and for use in a corporate environment:
Resource Allocation and Leveling.
Costing Functions.
Administrative Detail Editing (Notes assigned to tasks, Cost Account Codes, Manager Names, Unique Key for use in exporting to external databases).
Choice of Language for Dates.
Automatic Emphasis - an aid in selecting exporting details.
Hiding and Inactivating Dependency Links Grouped into "Families".
Specifying "Marginal" Criticality.
Each project may have its own resources list, or master resource lists may be maintained for use across projects.
Activities may be grouped into up to three levels, with resource cost summaries available at each level.
Spelling note: the correct spelling is "Gantt Chart", but if you are doing a web search for references to it you should also look for "Gant Chart", "Gaant Chart" and "Gannt Chart" since these are very common spelling errors.
Quick Start
If you want to start a project quickly - without worrying about theory, follow these steps.
1) Download and install PlanBee.
2) Click the "New" icon (the one at the left of the toolbar) or select File… New… and enter your project's basic details in the panel which appears. You may also set a start date in that panel. Then click the OK button.
3) Enter your first task's name and duration in Row 1 and press the [DOWNARROW] key on your keyboard.
4) Repeat to enter task 2 in row 2.
5) Repeat for all tasks.
6) Now it's time to enter "precedent dependencies". If you are laying a pipe, you must dig a trench first - you will have situations like this in your project. Select the row with the dependent activity (e.g. "Lay the Pipe") and click the "Add Precedent" button - a panel will appear with the other tasks listed. Select the "precedent task" in that list (e.g. "Dig the Trench") and click OK.
7) Do this for all tasks which depend on other tasks.
Congratulations, you have a plan.
俺也升为SCM版主了,呵呵
欢迎加水!
Steve
楼主 帅哥约,不在线,有人找我吗?lookmezh
来自 天津
发帖 1284篇
注册 2004/1/8
PM币 3600
经验 798点
Re:项目管理软件之planbee [回复于 2004/1/13]
可转至软件版,软件版有贴图功能。
传播项目管理能力
1楼 帅哥约,不在线,有人找我吗?易风
发帖 4895篇
PM币 3273
经验 11319点
Re:项目管理软件之planbee [回复于 2004/1/16]
谢谢. ^_^ 还不熟悉环境,请坛主多些KNOWHOW分享吧.
俺也升为SCM版主了,呵呵
欢迎加水!
Steve
2楼 帅哥约,不在线,有人找我吗?lookmezh
来自 天津
发帖 1284篇
注册 2004/1/8
PM币 3600
经验 798点
Re:项目管理软件之planbee [回复于 2004/2/2]
谢谢楼主!!
有好东东要提供啊!
http://www.pminnovation.org/index.php
没事干去这里混混就能找到意想不到的。。。
3楼 帅哥约,不在线,有人找我吗?magicnero
发帖 223篇
注册 2003/3/26
PM币 1675
经验 669点
不客气
俺也升为SCM版主了,呵呵
欢迎加水!
Steve
4楼 帅哥约,不在线,有人找我吗?lookmezh
来自 天津
发帖 1284篇
注册 2004/1/8
PM币 3600
经验 798点
Re:项目管理软件之planbee [回复于 2004/2/3]
请问,在哪里可以下载!
路漫漫其修远兮,吾将上下而求索!
MSN: Alan_dongjun@hotmail.com
Mail: Dongj@163.com
愿结识各界朋友!合作交友!
信息系统工程、咨询、服务。
5楼 帅哥约,不在线,有人找我吗?dongj
发帖 65篇
注册 2004/2/2
PM币 321
经验 96点
Re:项目管理软件之planbee [回复于 2004/2/5]
呵呵.要购买的.不是FREE
俺也升为SCM版主了,呵呵
欢迎加水!
Steve
6楼 帅哥约,不在线,有人找我吗?lookmezh
来自 天津
发帖 1284篇
注册 2004/1/8
PM币 3600
经验 798点
