[求助] 如何管理监理 [发表于 2005/5/26]
状态 开放帖 浏览量 718
作为一个房产公司的甲方项目经理,经过几个项目后,一直对监理的工作很不满意,监理或打着哈哈推责任,或与施工单位走的太近把关不严。
不知同行们可有良方指教?
楼主 帅哥约,不在线,有人找我吗?委员长
发帖 14篇
注册 2005/5/26
PM币 115
经验 22点
Re:[求助] 如何管理监理 [回复于 2005/5/26]
Yeah,it is a common problem in the project execution. Originally, I want the supervisor to be the representative of the buyers.Their responsibilities are to supervise and control the deeds of construction company.
I think you need to tell thim the ponderance of his duties.And at the same time, you should check the quality of the construction at any moment.If anythiny wrong happened,you should collect some materials to prove that it was his defult.
1楼 帅哥约,不在线,有人找我吗?sunnykeen
发帖 36篇
PM币 292
经验 58点
