再谈项目经理在企业中排第几? [karibu 修改于 2007/7/24]
状态 开放帖 精华贴 浏览量 1960
看到论坛中经常讨论“项目经理在企业中排第几?”这类问题。其实,作为项目经理的可悲之处在于他往往无权回答这个问题。
项目管理大师科兹纳在他的大作“Project Management: A Systems Approach to Planning, Scheduling, and Controlling”中对这个问题倒是有他的看法:
1.15 LOCATION OF THE PROJECT MANAGER
The success of project management could easily depend on the location of the project manager within the organization. Two questions must be answered:
  • What salary should the project manager earn?
  • To whom should the project manager report?
Figure 1-8 shows a typical organizational hierarchy (the numbers represent pay grades). Ideally, the project manager should be at the same pay grade as the individuals with whom he must negotiate on a daily basis. Using this criterion, and assuming that the project manager interfaces at the department manager level, the project manager should earn a salary between grades 20 and 25. A project manager earning substantially more or less money than the line manager will usually create conflict. The ultimate reporting location of the project manager (and perhaps his salary) is heavily dependent on whether the organization is project-or non–project-driven, and whether the project manager is responsible for profit or loss.
Figure 1-8: Organizational hierarchy.
Project managers can end up reporting both high and low in an organization during the life cycle of the project. During the planning phase of the project, the project manager may report high, whereas during implementation, he may report low. Likewise, the positioning of the project manager may be dependent on the risk of the project, the size of the project, or the customer.
Finally, it should be noted that even if the project manager reports low, he should still have the right to interface with top executives during project planning although there may be two or more reporting levels between the project manager and executives. At the opposite end of the spectrum, the project manager should have the right to go directly into the depths of the organization instead of having to follow the chain of command downward, especially during planning. As an example, see Figure 1-9. The project manager had two weeks to plan and price out a small project. Most of the work was to be accomplished within one section. The project manager was told that all requests for work, even estimating, had to follow the chain of command from the executive down through the section supervisor. By the time the request was received by the section supervisor, twelve of the fourteen days were gone, and only an order-of-magnitude estimate was possible. The lesson to be learned here is:
Figure 1-9: The organizational hierarchy: for planning and/or approval?
Note
The chain of command should be used for approving projects, not planning them.
Forcing the project manager to use the chain of command (in either direction) for project planning can result in a great deal of unproductive time and idle time cost.
对企业来说,“项目经理在企业中排第几?”实际上决定两个问题,第一是他的使用资源的能力,科兹纳认为一个项目经理至少应该具有和那些掌握人事适用的部门经理具有平等对话的权力(汗!我公司的项目经理实为部门经理的走卒,这是不符合项目管理精神的)。
第二个问题就是项目经理的话语权--报告关系。科兹纳认为这与项目的大小和时期有关系,项目越早的时候,报告层次应越高。特别在计划期,项目经理应该可以直接、越级向最高层作汇报,以避免时间的浪费。
科兹纳对项目经理级别的划分无疑是科学的?可实际中呢?每个项目经理可能都会有自己的感触。
本书下载:
http://www.mypm.net/bbs/article.asp?ntypeid=5037&titleid=52437
Here is Edward Bear, coming downstairs now, bump, bump, bump on the
back of his head, behind Christopher Robin.
It is, as far as he knows, the only way of coming downstairs,
but sometimes he-feels that there really is another way,
if only he could stop bumping for a moment and think of it.
And then he feels that perhaps there isn't.
楼主 帅哥约,不在线,有人找我吗?karibu
来自 辽宁
发帖 278篇
注册 2005/2/22
PM币 1599
经验 1956点
Re:再谈项目经理在企业中排第几? [回复于 2007/7/24]
Karibu, you always present us good idea.
1楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:再谈项目经理在企业中排第几? [回复于 2007/7/27]
其实我觉得项目经理排第几一点都不需要争议,我认为排名都是虚空的,事情做好才是关键。
不过我是在心中给项目经理定位第一的,一个项目的第一,不过是并列第一,哈哈......
2楼 美女约,不在线,有人找我吗?wangweizw
发帖 43篇
注册 2007/7/23
PM币 102
经验 72点
Re:再谈项目经理在企业中排第几? [回复于 2007/7/29]
wangweizw 在 2007-7-27 16:19:42 发表的内容
你要是能够好好的看看文章也学你不会这么骚。
3楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
在工程界往往有些老板自任PM,那么这个PM就是排位第一;但较多的是承接工程的老板自己不够专业,或已经赚够了钱不愿再这么辛苦了,而聘请PM,这时的PM排位第二。
4楼 帅哥约,不在线,有人找我吗?hyxiu
来自 福建省
发帖 518篇
注册 2005/11/2
PM币 2603
经验 1205点
Re:再谈项目经理在企业中排第几? [回复于 2007/8/21]
深有体会!
5楼 帅哥约,不在线,有人找我吗?ycheng30
来自 福建
发帖 178篇
注册 2007/6/30
PM币 510
经验 192点
承担多大的责任就应该有多达的话语全
6楼 帅哥约,不在线,有人找我吗?niles
发帖 519篇
注册 2006/3/7
PM币 635
经验 1080点
读完楼主的帖子,我的心情竟是久久不能平复,正如老子所云:大音希声,大象希形。我现在终于明白我们的企业缺乏的是什么了,参加了李尚泽博士的三天两晚完全掌握12门MBA /EMBA课程的精髓实战培训后,收到的效果真的是意想不到的。
这是威雅仕公司与著名实战派专家中欧商学院的院长李尚泽博士,历时8年研发出来的系统,决不可错过http://www.wejax.org
7楼 美女约,不在线,有人找我吗?yshanshan
发帖 59篇
注册 2007/8/21
PM币 205
经验 -5点
