Most important steps for a successful project [发表于 2007/8/27]
状态 开放帖 浏览量 612
http://www.visitask.com/steps-for-a-successful-project.asp
哈哈,看文字简单的不得了,做起来可没那么容易......
How many times have you heard about or been involved in a project that failed miserably? Or perhaps it just was not as successful as it needed to be. Did you ever spend time looking back to see what caused the project to go wrong. Next you have a few tips to help you understand what it takes to build a successfull project.
First of all you must know exactly what's your project about. You must discuss it with your team(if you have any) and you must agree precise specifications for it. You cannot start working until you have a well-defined idea in your mind.
Second of all you must plan the project. Here you should consider the time you need to finish it, the team you can relly on, the activities that must be done, the resources you have, and, of course, the financials.
During working time it's very important to communicate a lot with your team, to let them know what you managed to do, to ask questions and to give answers when needed. A lack of communication can lead to the failure of the project.
Also you must keep in mind to motivate and encourage your team when needed. You started the project as a team and you will finish it the same.
When the project is almost done you must check, measure and review it's plans. If you notice that something's wrong, you must inform you team and correct the errors. It's recommended not to leave this for the last moments when you don't have enough time to change anything.
After completing the project you must review it once more.If you are not pleased, don't start changing things because it could only be worse. It's very important to keep the armony and the well-organized shape of the project and changes on the spot can seriously affect that.
万籁此俱寂,但馀钟磬音。
ID NO:SHPM0188
MSN:glenliu1979@hotmail.com
http://spaces.msn.com/members/glenliu/
楼主 帅哥约,不在线,有人找我吗?ghliu
发帖 70篇
注册 2005/4/25
PM币 565
经验 142点
