可能以前会做过类似的测试,但这个附有完整的解释,值得再做. [发表于 2004/5/11]
状态 开放帖 浏览量 525
测试:
Hey it is quite accurate!!! Try and see!
嗨,这个测试很准的哦,来试试看。
Take a piece of paper and write down the answers.. The analysis is in the end....
请拿出一张纸一支笔把你的答案写下来,结论就在后面。
Situation: 场景:
You are in a deep deep forest... as you walk on you saw an old hut standing there
你在森林的深处,你向前走,看见前面有一座很旧的小屋。
(1) What is the status of the door? (Opened/closed)
这个小屋的门现在是什么状态?(开着/关着)
(2) You enter the hut and see a table... What is the shape of the table?
(Round/Oval/Square/Rectangle/Triangle)
你走进屋子里看见一张桌子
这个桌子是什么形状的?(圆形/椭圆形/正方形/长方形/三角形)
(3) On top of the table there is a vase... in the vase there is water. How much water is it filled up with?
(Full/Half/Empty)
在桌子上有个花瓶,瓶子里有水,有多少水在花瓶里?(满的/一半/空的)
(4) And what is the vase made of?
[(Glass/porcelain/clay)(metal/plastic/wood)]
这个瓶子是由什么材料制造的? (玻璃/陶瓷/泥土)(金属/塑料/木头)
(5) You walk out of the hut... as you carry on your walk in the forest... you see a waterfall from far...
there is water running down...What is the speed of the water?
(Choose a number ranging from 0 to 10)
你走出屋子,继续向森林深处前进,你看见远处有瀑布飞流直下,请问水流的速度是多少?
(你可以从0—10任意选一个)
(6) Some time after the waterfall... you step on something hard on the ground... as you look down... you see
glistening gold in colour. You bend down and pick it up... it is a keychain chained with keys...
How many key /keys you see hanging on the keychain? (Choose a number ranging from 1 to 10)
过了一会,你走过瀑布,你站在坚硬的地面上,你看见地上有金光闪烁,你弯腰拾起来,是一个带着钥匙的钥匙链。有多少把钥匙拴在上面,你可以任意选一个数字(从1到10)
(7) You walk on and on... trying to find your way out...suddenly you see a castle.
What is the condition of the castle? (Old/new)
你继续向前走,试着找出一条路来,突然你发现眼前有一座城堡。这个城堡是什么样的?
(旧的/新的)
(8) You enter the castle and saw a pool of murky water with shining jewels floating on it...Will you pick up the jewel? (YES/NO)
你走进城堡,看见一个游泳池,黑暗的水面上飘浮着很多闪闪发光的宝石,你会捡起这些宝石吗?(是/不)
(9) Next to the murky pool... there’s another pool... with clear water and money floating on it...
Will you pick the money? (YES/NO)
在这个黑暗的游泳池旁边还有一座游泳池。清澈的水面上飘浮着很多枚钱币。你会捡起这些钱币吗?(是/不)
(10) Walking to the end of the castle there is an exit...you proceed to walk out of the castle. Outside the
exit, there is big garden, you see a box on the ground. What is the size of the box? (small/medium/big)
你走到城堡的尽头有一个出口,你继续向前走走出了城堡。在城堡外面,你看见一座大花园,你看见地面上有一个箱子。这个箱子是多大尺寸的?(小/中/大)
(11) What is the material of the box? (cardboard/paper/wooden/metal)
这个箱子是什么材料做的? (硬纸板/纸/木头/金属)
(12) There is a bridge in the garden some distance away from the box, What is the bridge made of?
(metal/wooden/rattan)
花园里还有一座桥就在离着箱子的不远处。桥是什么材料建造的?(金属/木头/藤条)
(13) Across the bridge, there is a horse. What is the colour of the horse? (white/grey/brown/black)
走过这座桥,有一匹马。马是什么颜色的?(白色/灰色/褐色/黑色)
(14) What is the horse doing? (still and quiet/nibbling grass/running about)
马正在做什么?(安静地站着/吃草/在附近奔跑)
(15) OH NO!!! There is a tornado coming... some distance from the horse. You have 3 options:
(i) run and hide in the box?
(ii) run and hide under the bridge?
(iii) run to the horse, ride on and gallop away?
哦,不!离马很近的地方突然刮起了一阵龙卷风。你三种选择。
(1) 跑过去藏在箱子里?
(2) 跑过去藏在桥底下?
(3) 跑过去骑马离开?
  Here are the interpretations:
  好了,这就是我们的结论:
(1) The door:
opened door - you are a person who is willing to share
closed door - you are a person who is keeping things to yourself
门:
门如果是开着的:说明你是一个任何事都愿与别人分享的人
门如果是关着的:说明你是一个任何事都愿一个人去做的人
(2) The table:
Round/oval - any friends that came along, you will accept and trust them completely
圆形/椭圆形—总有一些朋友陪伴着你,你完全地信任并接受他们。
Square/rectangle - you are a bit more choosy on friends and only hang out with those whom you think are on the same frequency
正方形/长方形—你在交朋友的时候有点挑剔,你只是和那些你认为比较熟悉的朋友有一些来往。
Triangle - you are really very very picky about friends and there are not many friends in your life.
三角形—在对待朋友的问题上,你是一个真正的非常吹毛求疵的人,所以你的生活里没有许多朋友。
(3) Water in vase:
Empty - your life is not fulfilled
Half filled - what you want in your life is half fullfilled
Full - your life is completely fulfilled and good for you! :)
瓶子里的水
空的——你目前的生活很不满意。
一半——你的生活只有一半达到你的理想。
满的——你对目前的生活非常满意。
(4) Material of vase:
glass/clay/porcelain - you are weak in your life and tends to be fragile
瓶子的质地:
玻璃/泥土/陶瓷——在生活里你是一个脆弱而需要得到照顾的人。
metal/plastic/wood - you are strong in your life
金属/塑料/木头——你在生活里是一个强者。
(5) Flow of waterfall:
0 - no sex drive at all
1 to 4 - low sex drive
5 - average sex drive
6 to 9 - high sex drive
10 - gone case!!! super high sex drive!!! Can’t live without sex...
水流速度:
0— 你根本没有性欲
1— 4你的性欲很低
5— 中等水平的性欲
6— 9很强的性欲
10— 哇噻!你有超强的性欲,生活里没有性根本不行。
  (6) Keys:
1 - you have one good friend in your life
2 to 5 - you have a few good friends in your life
6 to 10 - you have a lot good friends
钥匙:
1—生活中你只有一个好朋友。
2— 5生活中你有一些好朋友。
6—10生活中你有许多好朋友。
  (7) Castle:
    Old - shows that your last relationship is not a good one and is not memorable to you.
    New - your last relationship is good and it’s still fresh in your heart.
城堡:
旧的—显示你在过去的交往中有一段不好的和不值得纪念的关系。
新的—显示你在过去的交往中有一段很好的交往现在仍然鲜活的驻留在你心里。
  (8) The jewel from the murky pool water:
YES - when your partner is around you, you will flirt around with others.
NO - when your partner is around, you will stick around with him/her most of the time.
从脏水的游泳池里捡宝石:
是—当你的伴侣在你身边时,你依然和周围的人调情。
不—当你的伴侣在你身边里,你绝大多数时间只会围着他/她转。
(9) The money from the clear water pool:
YES - when your partner is not around you, you will still flirt around with others.
NO - even when your partner is not around, you will still think of her and and will be loyal to him/her, not flirting around with others.
从清澈的游泳池里捡钱币:
是——当你的伴侣不在你身边,你会和周围的人调情。
不——当你的伴侣不在你身边,你也会忠实于他/她,不和周围的人调情。
(10) The size of the box:
small - low ego
medium - average ego
big - high ego
箱子的大小
小—不自负
中等—比较自负
大—非常自负
(11) Material of the box (outlook of the box):
cardboard/paper/wooden(non-shining) – humble personality
metal - proud and stuck up personality
箱子的材料(从表面看)
硬纸/纸/木头(不闪光)——谦虚的性格
金属——骄傲而顽固的性格
(12) The material of the bridge:
metal bridge - have very strong bond with your friends
wooden bridge - average bond with your friends
rattan bridge - you are not in good terms with your friends
桥的材料
金属——和朋友有非常紧密的联系
木头——和朋友有比较紧密的联系
藤条——周围没有很好的朋友
(13) Colour of the horse:
white - your partner is pure and good in your heart.
grey/brown - your partner is only average in your heart.
black - your partner doesn’t seem to be good in your heart and appears to be bad sign.
马的颜色:
白色——你的伴侣在你心目中非常纯洁而美好。
灰色/褐色——你的伴侣在你心目中的位置一般。
黑色——你的伴侣在你心目中好像根本不怎么样,甚至还很坏。
(14) Horse action:
still and quiet/nibbling grass - your partner is a very homely and humble person.
running about - your partner is a wild type person.
马的动作:
安静/吃草——你的伴侣是一个顾家的,谦虚的人。
在附近奔跑——你的伴侣是一个非常狂野的人。
(15)This the last but most important part of the test.
From how I ended the story... a tornado approaches...
What are you going do? There are only 3 options:
这是最后一个问题但也是最重要的问题。对了,故事的结尾是一阵龙卷风,
你怎么去做呢?这里提供了三种选择:
(i) 跑过去藏在箱子里面?
(ii) 跑过去藏在桥下面?
(iii) 跑过去骑上马走?
What will you choose?
Now, the above is signified by these things:
tornado - problems in your life
box - you
bridge - your friends
horse - your partner
那么什么是你的选择呢?
现在,我们看看上面的这些事物代表的是什么:
龙卷风——你生活中的麻烦
箱子——你自己
桥——你的朋友
马——你的伴侣
(i) So if you choose the box, you keep your problems to yourself whenever you are met with problems.
(ii) or if you choose the bridge, you will go to your friends whenever you are met problems.
(iii) or lastly if you choose the horse, you seek your partner whenever your partner whenever you are met
with problems.
(i)如果你选择箱子,你无论何时遇到麻烦你都会自己解决。
(ii)或者你选择桥,无论何时你遇到麻烦你都有将去找你的朋友一起解决。
(iii)又或者你选择的最后一个马,你寻找的伴侣是你无论何时遇到麻烦都要和他/她一起去面对。
我追求,我攀登,我进取。
喜欢雨,也喜欢百合,雨中的百合带着雨滴。。。
MSN:jannygogogo@hotmail.com
楼主 美女约,不在线,有人找我吗?aupres
发帖 199篇
PM币 941
Re:可能以前会做过类似的测试,但这个附有完整的解释,值得再做. [回复于 2004/5/13]
我想问问,到底是测试什么的啊???
1楼 帅哥约,不在线,有人找我吗?大眼睛
发帖 1709篇
注册 2004/1/30
PM币 3456
经验 1296点
Re:可能以前会做过类似的测试,但这个附有完整的解释,值得再做. [回复于 2004/5/14]
以前做过的测试结果和这次做得很不同啊,不知道是自己成长了,还是心理暗示什么的。
2楼 美女约,不在线,有人找我吗?samansa
发帖 162篇
注册 2004/3/27
PM币 450
经验 -15点
复习一下单词倒是不错,吼吼
人生没有彩排,只有现场直播
Tom.Kaizer.Yin
3楼 帅哥约,不在线,有人找我吗?yin
发帖 1394篇
注册 2003/4/10
PM币 3653
经验 1141点
yin,我辛辛苦苦的,就这作用呀。。
我追求,我攀登,我进取。
4楼 美女约,不在线,有人找我吗?aupres
发帖 199篇
PM币 941
不是拿我们做实验吧?!
5楼 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
