Project Server 2010 Hardware and Software Requirements [发表于 2010/9/10]
状态 开放帖 浏览量 1201
该帖子同步发自:(high_far的博客  访问该博客)
NOTE: The following hardware and software requirements also applicable for SharePoint 2010.
Project Server 2010/SharePoint 2010 must be installed on either 64-bit Windows Server 2008 SP2 or Windows Server 2008 R2.
Your database servers for a Project Server 2010/SharePoint 2010 farm deployment must be the 64-bit version of either SQL Server 2005 with SP3 or SQL Server 2008 or SQL Server 2008 R2.
HARDWARE REQUIREMENTS:
Project Server 2010/SharePoint 2010 Machine:
  • 64 bit computer
  • Minimum four cores
  • 8 GB RAM or more
  • 80 GB for installation and total 250 GB of free disk space for day-to-day production use
  • DVD Drive
Database Server Machine:
  • 64 bit computer
  • Minimum four cores processor for small deployment; Minimum 8 cores for medium to large deployments
  • Minimum 8 GB RAM for small deployments; 16 GB RAM for medium deployments; 32 GB to 64 GB for large deployments
  • 80 GB for installation and total 250 GB of free disk space for day-to-day production use (For medium to large deployments, see the Estimate memory requirements section on Microsoft site.
  • DVD Drive
SOFTWARE REQUIREMENTS:
  • Operating System: 64 bit edition of Windows Server 2008 R2 or Standard or Enterprise or Data Center or Web Server edition with SP2
  • Microsoft SharePoint 2010 Enterprise Edition
  • Microsoft Internet Explorer 7 or Microsoft Internet Explorer 8
NOTE: Windows Server 2008 R2 is recommended; It is not possible to install Project Server 2010 on SharePoint 2010 standard edition.
  • Database Edition: 64 bit edition of Microsoft SQL Server 2008 R2
              Or
    64 bit edition of Microsoft SQL Server 2008 with Service Pack 1 (SP1) and Cumulative Update 2
              Or
    64 bit edition of Microsoft SQL Server 2005 with Service Pack 3 (SP3)
  • Microsoft Internet Explorer 7 or later
NOTE: SQL Server 2008 R2 with Windows Server 2008 R2 is recommended.
SQL Server 2008 R2 version includes updates in SQL Server 2008 Reporting Services (SSRS) like connectivity to SharePoint lists and the PowerPivot for Excel feature.
When you install Microsoft SQL Server 2008 SP1 on Windows Server 2008 R2, you might receive a compatibility warning. You can ignore this warning and continue with your installation.
Huibin Zhang
Microsoft MVP
Microsoft Project Consultant
mail:highfar.zhang@gmail.com
mail:v-huibin@microsoft.com
blog:http://highfar.mypm.net
www.highfarinfo.com
楼主 帅哥约,不在线,有人找我吗?high_far
发帖 371篇
注册 2003/6/2
PM币 2031
经验 1223点
