三道题 [发表于 2003/9/16]
状态 开放帖 浏览量 1566
49. 3.5 Milestones are not-
里程碑不是 [ ]
a. Activities of zero duration
持续期为零的工作
b. Significant events in the project life cycle
项目生命周期中重要的事件
c. Measures of achievement for expenditures of money or time
因资金或时间的付出而取得的工作成果的度量
d. Best utilized when denoting start and finish of all activities
在表示所有工作开始和结束时,得到最好利用
54. 3.15 Fast-tracking means- 快速跟进的意思的 [ ]
a. Reducing the duration of critical path activities to shorten project duration
缩短关键路径工作周期,以缩短项目周期
b. Reducing project duration by redefining logical relationships
通过对各种逻辑关系再确定来缩短项目周期
c. Using only the best resources to accomplish work as quickly as possible
只使用最好的资源以尽快完成工作
d. Coordinating efforts with other projects to reduce administrative friction
同其他项目协调好关系以减少管理的磨擦
67. 3.39 In project time management, crashing means-
在项目的时间管理中,项目赶工的意思是: [ ]
a. Reducing project duration by redefining logical relationships
重新界定逻辑关系,以缩短项目周期
b. Reducing computer network downtime for schedule risk modeling
缩短用于项目进度风险模型分析的计算机网络维修时间
c. Applying additional resources to all project activities
给所有的项目工作都增加新的资源
d. Applying additional resources to critical path activities by priority
根据优先顺序给重要路径上的活动增加资源
楼主 帅哥约,不在线,有人找我吗?我笨笨
发帖 249篇
注册 2003/8/25
PM币 1127
经验 51点
Re:三道题 [回复于 2003/9/18]
看样子这块论坛的盟友对PMP考试关注的人不多啊
DAD 不知对不对?
1楼 帅哥约,不在线,有人找我吗?howard_hong
发帖 1036篇
注册 2003/6/6
PM币 3684
经验 5061点
DBD
2楼 帅哥约,不在线,有人找我吗?我笨笨
发帖 249篇
注册 2003/8/25
PM币 1127
经验 51点
中间一道题,答案在A、B之间当时我选的时候就是拿不准。
3楼 帅哥约,不在线,有人找我吗?howard_hong
发帖 1036篇
注册 2003/6/6
PM币 3684
经验 5061点
Re:三道题 [回复于 2003/9/19]
Fast Tracking
Compressing the project schedule by doing some or all of certain activities in parallel that would normally be done in sequence (such as design and construction). [D00663]
PMK96
The process of reducing the number of sequential relationships (FS) and replacing them typically with parallel relationships (SS). [D00664]
WST
Reducing the duration of a project usually by overlapping phases or activities that were originally planned be to done sequentially. [D04579
4楼 帅哥约,不在线,有人找我吗?yklee
发帖 18篇
注册 2003/9/5
PM币 134
经验 37点
所以应为B
5楼 帅哥约,不在线,有人找我吗?yklee
发帖 18篇
注册 2003/9/5
PM币 134
经验 37点
Re:三道题 [回复于 2003/9/22]
哦,PMBOK上有这样一段描述?中文版的有吧?
书到用时方嫌少,多读书,读好书
--------广州项目管理俱乐部-------
欢迎加入QQ群4315886讨论微软Project软件
6楼 帅哥约,不在线,有人找我吗?gentou
发帖 825篇
注册 2003/8/7
PM币 1444
经验 184点
找到了,在附件的术语中,呵呵
书到用时方嫌少,多读书,读好书
7楼 帅哥约,不在线,有人找我吗?gentou
发帖 825篇
注册 2003/8/7
PM币 1444
经验 184点
