各位高手快来帮我解决解决!!! [发表于 2003/7/9]
状态 开放帖 浏览量 3287
本人使用的是project 2002 professional, server.
公司的IT说配置是没有问题的,但为什么我的project 发布出来后都是non-enterprise project?这样我就不能在resource center里管理和编辑我的resource, 我也想过解决的办法,但还是不行。
我在project 的tools中设置过,但说没有成功,给出了原因,我排除了一下,有可能是我们的' global template'的问题,有那位高人可以指点一下,将不胜感激。
楼主 美女约,不在线,有人找我吗?wendy
发帖 7篇
注册 2003/7/9
PM币 121
Re:各位高手快来帮我解决解决!!! [回复于 2003/7/9]
问TOSEA,他PROJECT很熟!
1楼 帅哥约,不在线,有人找我吗?howard_hong
发帖 1036篇
注册 2003/6/6
PM币 3684
经验 5061点
Re:各位高手快来帮我解决解决!!! [回复于 2003/7/10]
谢了。
2楼 美女约,不在线,有人找我吗?wendy
发帖 7篇
注册 2003/7/9
PM币 121
Re:各位高手快来帮我解决解决!!! [回复于 2003/7/14]
请问你的project 2002 professional启动的时候联server了么?
如果联了应该没问题啊
3楼 帅哥约,不在线,有人找我吗?wangxh1000
发帖 -4篇
注册 2007/12/8
PM币 -90
经验 1点
请参看“[求助] help!!! ”帖
再来一个完整的,[转贴自微软project新闻组]
You must be logged into Project Server using a valid user account before you
can publish an enterprise project. Try the following:
1. Open Microsoft Project
2. Click Tools - Enterprise Options - Microsoft Project Server Accounts...
3. In the Microsoft Project Server Accounts dialog box, make sure that you
have a valid user account listed which has Project Manager permissions (if
one does not exist, then create it and test it)
4. Select your account with PM persmissions and click the Properties...
button
5. In the Properties dialog box, select the "Set as default account" option
and click the OK button
6. In the Microsoft Project Server Accounts dialog box, select the
"Manually control connection state" option and then click the OK button
7. Close Microsoft Project 2002, and then reopen Microsoft Project 2002
8. In the Microsoft Project Server Accounts dialog box, make sure your PM
account is selected, then click the Connect button
Once you have done this, you are logged into the Microsoft Project Server
environment, are ready to use enterprise features like the Enterprise
Resource Pool and Enterprise Global, and are ready to publish your first
enterprise project. Good luck! Hope this helps.
Dale A. Howard
Project Management Trainer/Consultant
Denver, CO
4楼 帅哥约,不在线,有人找我吗?wangxh1000
发帖 -4篇
注册 2007/12/8
PM币 -90
经验 1点
谢谢
我可以发布PROJECT 到SERVER上,但发布出来的不是ENTERPRISE的,所有的步骤我都设过的,但再登陆的时候,如果是以我的ACCOUNT进入的话就无法连接,有几个原因,排除了一下,最象的是the lake of enterprise global template.
说我的server may not have enterprise feature enable
但我们的admin说他的安装绝对是超标准的。
帮我分析以下,这会是在哪出现了问题呢?
5楼 美女约,不在线,有人找我吗?wendy
发帖 7篇
注册 2003/7/9
PM币 121
Re:各位高手快来帮我解决解决!!! [回复于 2003/7/15]
如果说是"server may not have enterprise feature enable",禁用了企业功能
那请到project server的“管理”——“管理企业功能”——“功能”中勾一下“启用企业功能”
6楼 帅哥约,不在线,有人找我吗?wangxh1000
发帖 -4篇
注册 2007/12/8
PM币 -90
经验 1点
server中的这一项我们设过的,但还是没有用,所以我一直怀疑是我们global的问题,server 中是不是有两种形式的摸板啊?即使我们装了professional project ,这个global template不对还是不能发布enterprise project, 但我就搞不懂,这个enterprise global 难道是个单独的东西?他是存在哪里的一个文件啊?
7楼 美女约,不在线,有人找我吗?wendy
发帖 7篇
注册 2003/7/9
PM币 121
应该和global template没关系把
找找看是不是别的配置问题把
在project pro+project server环境中enterprise global存在project server上
8楼 帅哥约,不在线,有人找我吗?wangxh1000
发帖 -4篇
注册 2007/12/8
PM币 -90
经验 1点
