求助!project server2003安装问题 [发表于 2006/6/6] 状态 开放帖 浏览量 1272 |
我在安装Project Server2003中,运行windows sharepoint services配置向导时,sharepoint configuration出错了,提示缺少项目工作模板,具体提示内容是: sharepoint configuration wizard cannot create the MS_ProjectServer_PublicDocuments site with the template that you have selected. You must use the project workspace template or any other template you have created by using the project workspace template. Ensure that the template has been installed into the corret directory, and then run the sharepoint configuration wizard again. 请问怎么安装模板?我把默认网站升级为顶级网站,进入模板选择 页面,但是不能保存模板:( 希望得到大家的帮助。谢谢!
joycewu
发帖 11篇
注册 2006/5/16
PM币 95
Re:求助!project server2003安装问题
[回复于 2006/6/6]
哪位大虾帮帮手啊
-------------------------------------------------------------------------------------------------------- 金鳞岂是池中物,一遇风云便化龙……
jamliu
发帖 87篇
注册 2005/11/29
PM币 445
[回复于 2006/6/7]
没有人帮忙啊?!难道大家没有出现过这个问题么?
joycewu
发帖 11篇
注册 2006/5/16
PM币 95
high_far
发帖 371篇
注册 2003/6/2
PM币 2031
[回复于 2006/6/8]
我先装了SQL 然后share point 然后配置向导。。。之后就这样了
jamliu
发帖 87篇
注册 2005/11/29
PM币 445
[回复于 2006/6/10]
希望大家能给予帮助,谢谢
jamliu
发帖 87篇
注册 2005/11/29
PM币 445
[回复于 2006/6/11]
这个问题我已经解决了,是wsswiz.exe版本的问题,wsswiz.exe是project server自带的。你告诉我email,我发给你试试吧^_^
joycewu
发帖 11篇
注册 2006/5/16
PM币 95
[回复于 2006/6/12]
jam1981@163.com
jamliu
发帖 87篇
注册 2005/11/29
PM币 445
[回复于 2006/6/18]
收藏了
1983superman
发帖 21篇
注册 2006/6/18
PM币 -135
