软件的技术指标都有哪些呢? [发表于 2006/9/20]
状态 开放帖 精华贴 浏览量 10204
软件的技术指标都有哪些呢?
楼主 美女约,不在线,有人找我吗?cmag
发帖 291篇
注册 2006/9/8
PM币 3160
经验 1547点
Re:软件的技术指标都有哪些呢? [回复于 2006/9/20]
有好几点,我记不得那么多了。
安全性,
交互性,
易用性,
稳定性,
性能好,
容错性,
负载平衡性等。
1楼 美女约,不在线,有人找我吗?XO
发帖 436篇
注册 2005/1/7
PM币 10955
经验 3093点
软件技术指标分成功能指标和非功能指标
功能指标当然是平时各家软件开发商乐于吹嘘的,提供*****功能,听多了就烦的事情
非功能指标就如dichun(融雪)提到的,以性能参数/安全性/扩展性/部署方便性/可用性等来衡量,这是国内软件开发商都在逃避的指标
仅供参考
unow2005.tianyablog.com
PMP认证,项目经理最佳选择!
2楼 帅哥约,不在线,有人找我吗?domo
发帖 363篇
注册 2005/1/7
PM币 4082
经验 1295点
受教了
3楼 帅哥约,不在线,有人找我吗?niles
发帖 519篇
注册 2006/3/7
PM币 635
经验 1080点
Availability  The degree to which a system is accessible. The term 24×7 describes total
   availability. This aspect of a system is often coupled with performance.
Reliability  The ability to ensure the integrity and consistency of an application and its transactions.
Manageability  The ability to administer and thereby manage the system resources to ensure the
   availability and performance of a system with respect to the other capabilities.
Flexibility  The ability to address architectural and hardware configuration changes without a
   great deal of impact to the underlying system.
Performance  The ability to carry out functionality in a timeframe that meets specified goals.
Capacity  The ability of a system to run multiple tasks per unit of time.
Scalability  The ability to support the required availability and performance as transactional
   load increases.
Extensibility  The ability to extend functionality.
Validity  The ability to predict and confirm results based on a specified input or user gesture.
Reusability  The ability to use a component in more than one context without changing its internals
Security  The ability to ensure that information is not accessed and modified unless done so
   in accordance with the enterprise policy.
4楼 帅哥约,不在线,有人找我吗?yuanyipin
来自 辽宁
注册 2006/9/20
PM币 50
经验 13点
以上指标其实系统的指标,其实也是软件实现的指标。
5楼 帅哥约,不在线,有人找我吗?yuanyipin
来自 辽宁
注册 2006/9/20
PM币 50
经验 13点
