晓龙
登录:2015/5/22
次数:59
注册:2008/4/22
发帖:84
ZZPCHINA
登录:2015/3/7
次数:82
注册:2012/8/2
发帖:141
Lean Six Sigma [发表于 2007/1/18]
状态 开放帖 浏览量 3252
I bought a book on Lean Six Sigma from Shenzhen Bookstore.
The book combines the two most important improvement trends of our time: making work better (using Six Sigma) and making work faster (using Lean principles).
The idea is to lean the things first, then improve it better! It's a good book and make the concept easy to understand and you can try to apply the tools in your daily work.
Email/MSN :lenalee688@hotmail.com
Blog:http://lenaning.mypm.net
楼主 美女约,不在线,有人找我吗?lenaning
发帖 84篇
注册 2005/8/20
PM币 674
经验 230点
Re:Lean Six Sigma [易风 修改于 2007/1/18]
can you give the internet link of the book? what does the Lean principles incule?
传播项目管理能力
1楼 帅哥约,不在线,有人找我吗?易风
发帖 4895篇
PM币 3273
经验 11319点
Re:Lean Six Sigma [回复于 2007/1/19]
You can find this book in bookstore I think, author is Michael L George. You can find the book in bookstore.
China Machine Press translated it into Chinese and I found some of the translations really hard to understand. For example: delivery lead time tanslated as 提前期, I think 交货期 is more easier to be understood.
2楼 美女约,不在线,有人找我吗?lenaning
发帖 84篇
注册 2005/8/20
PM币 674
经验 230点
Re:Lean Six Sigma [回复于 2007/3/13]
can you tell us the name of the book , then we will try to look for it in interenet source
生当作人杰,死亦为鬼雄!
3楼 帅哥约,不在线,有人找我吗?lvbuhxl
发帖 17篇
注册 2007/2/28
PM币 93
经验 60点
Re:Lean Six Sigma [回复于 2007/3/21]
can you scan the book to e-version and upload here ,share with all, 3Q
4楼 帅哥约,不在线,有人找我吗?argus
发帖 85篇
注册 2006/9/14
PM币 580
经验 152点
Re:Lean Six Sigma [回复于 2008/5/22]
Company indroduction in progress.
5楼 帅哥约,不在线,有人找我吗?csbu2738
来自 天津
发帖 25篇
注册 2008/5/22
PM币 10
经验 36点
Re:Lean Six Sigma [回复于 2008/5/31]
I have heard it in a training class. Not difficult (I mean no difficult calculation as 6-sigma), easy to understand and excute.
6楼 美女约,不在线,有人找我吗?caiaijun
来自 福建
注册 2008/5/26
PM币 35
经验 10点
Re:Lean Six Sigma [回复于 2012/2/23]
Six Sigma is a data-driven framework designed by Motorola to make breakthrough, rather than incremental, quality improvements in an organization's value-adding processes while simultaneously saving money or increasing revenues. This represnts the goal of having a defect occur in a process only 0.00034 percent of the time, or 3.4 times out of every million measurement opportunities - a goal beyond the reach of the typical organization today. Six Sigma is also ment to embody a philosophy or culture in which everyone from CEO to frontline service employee is involved in improving quality and uses a project management approach.
Lean operations ia a phrase coined in the United States but is based on the Toyata Production System ( TPS) and a philosophy of continuous improvement. The TPS follows a philosophy of continuous learning and keeping things simple. An organization should make the est use of its time, people and physical assests to optimize productivity. Organizations also work to connect each value-added step in a process, in the best sequence and most effective way possible without imterruption.
7楼 美女约,不在线,有人找我吗?lenaning
发帖 84篇
注册 2005/8/20
PM币 674
经验 230点
