说明:联盟上海俱乐部会员交流区
Dill
登录:2017/10/30
次数:311
注册:2004/7/5
发帖:448
winnee
登录:2011/7/18
次数:18
注册:2009/11/11
发帖:27
PMP试题,寻答案 [发表于 2005/9/23]
状态 开放帖 浏览量 3300
117. Which of the following factors contributes the most to team communication? 以下哪一个因素对于项目团队成员之间的沟通意义最为重大:[ ]
a. External feedback 来自于外部的意见反馈
b. Performance appraisals 执行情况评估
c. Smoothing over of team conflicts by the project manager 项目经理解决项目小组成员之间的矛盾与冲突
d. Collocation 集中办公
124. The method most often used by project managers to solve conflict is— 最常被项目经理用来解决冲突的方法是:[ ]
a. Compromise 妥协的方式
b. Confrontation 对话
c. Smoothing 消除冲突
d. Negotiation 谈判
131. When choosing the most appropriate form of project organization, the first step is to— 在选择最佳的项目组织形式时,第一步是:[ ]
a. Create the WBS and let it determine the project organizational structure 建立 WBS ,并由它决定项目的组织结构
b. Produce an initial project plan and determine the functional areas responsible for each task 制度初期项目计划,确定每项任务的职能领域
c. Refer to the project charter developed by top management 参考由最高管理层制定的项目章程
d. Develop a project schedule, including a top-down flowchart, and identify the functional areas to perform each task 制定项目进度表,包括流程图,并确定负责单项任务的职能单位
161. Range estimating identifies all the following except—— 范围估计时不用考虑以下哪项:[ ]
a. Mathematical probability that a cost overrun will occur 费用超支发生的可能性
b. risks and opportunities ranked in order of bottom-line importance 处于底线重要性的风险和机会
c. The contingency required for a given level of confidence 在一定置信区间的应急事项
d. The specific risk event impacting the estimate 影响估计的特殊风险事情
184.While working on a project at a client site, you accidentally discover some of the client’s proprietary information. What is your NEXT step? 在某客户的现场进行项目作业之间,您意外发现客户的一些内部信息。您下一步怎么办?[ ]
A.Excuse yourself from the remainder of project 自己要求离开项目的剩余部分工作
B.Inform the client of the breach 将此违约事件通知客户
C.Continue on the project, keeping the discovery to yourself 继续实施项目,将此发现秘而不宣
D.Review the information with your manager 与您的经理查阅该信息
谢先!
路漫漫其修远兮,
吾将上下而求索!
楼主 帅哥约,不在线,有人找我吗?lsl_david
发帖 32篇
注册 2007/9/8
PM币 180
经验 68点
Re:PMP试题,寻答案 [回复于 2005/9/23]
怎么没有高手指教啊,请不吝赐招!!
路漫漫其修远兮,
吾将上下而求索!
1楼 帅哥约,不在线,有人找我吗?lsl_david
发帖 32篇
注册 2007/9/8
PM币 180
经验 68点
Re:PMP试题,寻答案 [非常项目经理 修改于 2005/9/24]
184 =C 那些是情与你无关
肖像释义
不必在意我的容颜
那是被IT项目拖累的 只剩下一堆白骨
还有飘荡其中的 久久不能淡去的感悟
2楼 帅哥约,不在线,有人找我吗?非常项目经理
发帖 1567篇
注册 2007/4/9
PM币 10075
经验 2126点
Re:PMP试题,寻答案 [回复于 2005/9/24]
161 =A 范围估计时不用考虑的就是成本和费用
肖像释义
不必在意我的容颜
那是被IT项目拖累的 只剩下一堆白骨
还有飘荡其中的 久久不能淡去的感悟
3楼 帅哥约,不在线,有人找我吗?非常项目经理
发帖 1567篇
注册 2007/4/9
PM币 10075
经验 2126点
131 =C
肖像释义
不必在意我的容颜
那是被IT项目拖累的 只剩下一堆白骨
还有飘荡其中的 久久不能淡去的感悟
4楼 帅哥约,不在线,有人找我吗?非常项目经理
发帖 1567篇
注册 2007/4/9
PM币 10075
经验 2126点
124 =C 如果没有记错的话 这道题书上有定义的
肖像释义
不必在意我的容颜
那是被IT项目拖累的 只剩下一堆白骨
还有飘荡其中的 久久不能淡去的感悟
5楼 帅哥约,不在线,有人找我吗?非常项目经理
发帖 1567篇
注册 2007/4/9
PM币 10075
经验 2126点
117 =D ?
肖像释义
不必在意我的容颜
那是被IT项目拖累的 只剩下一堆白骨
还有飘荡其中的 久久不能淡去的感悟
6楼 帅哥约,不在线,有人找我吗?非常项目经理
发帖 1567篇
注册 2007/4/9
PM币 10075
经验 2126点
Re:PMP试题,寻答案 [回复于 2005/9/27]
谢谢指点。
上面在资料上给的答案是:D D C D D
对于上面的124和最后面2题,说不上上面理由,大家讨论一下。
路漫漫其修远兮,
吾将上下而求索!
7楼 帅哥约,不在线,有人找我吗?lsl_david
发帖 32篇
注册 2007/9/8
PM币 180
经验 68点
184我选C. 不小心看到客户内部信息应该保密, 而不是继续传播给经理.
8楼 帅哥约,不在线,有人找我吗?jacago
发帖 16篇
注册 2005/9/25
PM币 95
经验 17点
