说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
Some Management Styles [轻轻松松 修改于 2004/8/15]
状态 开放帖 浏览量 2330
One of the following management approaches that a project manager may adopt depending on the situation: authoritarian autocratic, combative, conciliatory, consensual, consultative-autocratic, democratic, disruptive, ethical, facilitating, intimidating, judicial, laissez-faire, participative, promotional, secretive, shared leadership, or shareholder manger style.
Autocratic management style.
Management approach in which the project manager makes all decisions and exercises tight control over the project team. This style is characterized by communications from the project manager downward to the team and not vice versa.
Authoritarian management style.
Management approach in which the project manager tells team members what is expected of them, provides specific guidance on what should be done, makes his or her role within the team understood, schedules work, and directs team members to follow standard rules and regulations.
Combative management style.
Management approach in which the project manager displays an eagerness to fight or be disagreeable over any given situation.
Conciliatory management style.
Management approach in which the project manager is friendly and agreeable and attempts to unite all project parties involved to provide compatible working team.
Consensual management style.
Management approach in which the project manager presents problems to team members for discussion or input and encourages them to make decisions. This approach results in an increase in team member commitment to the group decision but also in the amount of time required to reach that decision.
Democratic management style.
Participative management approach in which the project manager and project team make decisions jointly.
Disruptive management style.
Management approach in which the project manager tends to destroy the unity of the team, be an agitator, and cause disorder on the project.
Facilities management style.
Management approach in which the project manager makes himself or herself available to answer questions and provide guidance when needed but does not interfere with day-to-day tasks.
Intimidating management style.
Management approach in which the manager frequently reprimands team members, to uphold his or her image as a demanding manger, at the risk of lowering team morale.
Judicial Management Style.
Management approach in which the project manager exercises sound judgment and applies it to project issues as the need arises.
Laissez-faire management style.
Management approach in which team members are not directed by management. Little information flows from the project team to the project manager, or vice versa. This style is appropriate if the team is highly skilled and knowledgeable and wants no interference by the project manager.
Participative management style.
Management approach in which the project manager solicits information from and shares decision-making with the project team.
Secretive management style.
Management approach in which the project manager is neither open nor outgoing in speech, activity, or purpose, to the detriment of the project.
楼主 帅哥约,不在线,有人找我吗?轻轻松松
Re:Some Management Styles [回复于 2004/8/2]
thanks
1楼 帅哥约,不在线,有人找我吗?eveningstar
发帖 1689篇
注册 2004/4/7
PM币 1361
经验 162点
Re:Some Management Styles [回复于 2004/8/13]
THANKS ! 能否提供中文的?
陕西德之项目管理发展有限责任公司
信息系统、网络、安防等设计咨询服务;
工程项目管理咨询、服务;
造价咨询、招投标代理
QQ:1215023087
2楼 帅哥约,不在线,有人找我吗?chpj006
发帖 368篇
注册 2004/8/9
PM币 3
经验 475点
Re:Some Management Styles [回复于 2004/8/15]
谁有兴趣可以来翻译一下。
PS:不过有时候还是读E文的舒服一些。
3楼 帅哥约,不在线,有人找我吗?轻轻松松
Re:Some Management Styles [回复于 2004/8/19]
mushroom management style
4楼 帅哥约,不在线,有人找我吗?whboy
注册 2003/11/8
PM币 264
经验 38点
Re:Some Management Styles [回复于 2005/2/12]
great thanks!
5楼 帅哥约,不在线,有人找我吗?stoneh8
发帖 106篇
注册 2007/3/24
PM币 346
经验 316点
Re:Some Management Styles [回复于 2006/7/17]
学习
6楼 帅哥约,不在线,有人找我吗?abc123cn
发帖 277篇
注册 2006/7/17
PM币 330
经验 490点
Re:Some Management Styles [回复于 2006/12/1]
有意思
7楼 帅哥约,不在线,有人找我吗?cxd3008
来自 天津
发帖 150篇
注册 2006/11/28
PM币 105
经验 229点
Re:Some Management Styles [回复于 2006/12/26]
very good
8楼 帅哥约,不在线,有人找我吗?spider1999
发帖 126篇
注册 2005/2/28
PM币 330
经验 360点
