说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
Pert与CPM的比较(项目管理术语每周一讲) [Bigpond 修改于 2004/8/12]
状态 开放帖 精华贴 浏览量 13361
PERT Compared with CPM
When most of the activities in a project are similar to other activities that have been performed a large number of times, CPM scheduling is generally used. With CPM, estimates of activity durations are based on historical data and are assumed to be the mean or average time that the activity has taken to perform in the past.
However, when a project contains a majority of activities for which no experience exists (that is, when no historical data is available ) the estimating difficulty becomes significant. With no experience to serve as a guide, the only solution is to make the best possible guess, using whatever relevant experience available.
It seems clear, however, that the more unique an activity is, the less certain the estimate of its duration and, therefore, the more risky the project will be in terms of control. And since a lot of projects (such as research and development) fall into this category, the question naturally arises as to whether some method might be employed to reduce estimating risk.
It was in response to this problem that PERT was developed around 1957 as a joint effort between the U.S. Navy and the consulting firm of Booz, Allen, and Hamilton. The concept was originally applied to the Polaris submarine project.
Although estimates of activity durations for CPM projects are taken as averages based on history, once they are in place, they are often assumed to be more or less fixed or, to use the colloquial expression, they are “engraved in granite.” The PERT system, however, is based on the recognition that estimates are uncertain, and therefore it makes sense to talk of ranges of durations and the probability that an activity duration will fall into that range, rather than assuming that an activity will be completed in a fixed amount of time.
看别人不顺眼,
是自己修养不够
楼主 帅哥约,不在线,有人找我吗?Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
经验 332点
Re:Pert与CPM的比较(项目管理术语每周一讲) [Bigpond 修改于 2004/8/12]
PERT和CPM的比较
当一个项目中的大多数活动同以往执行过很多次的其他活动类似时,通常采用关键路径法(CPM)进行计划编制。CPM的活动历时估算通常以历史数据为基础,并且采用以往项目活动历时的平均值。
但是,如果一个项目包括的绝大多数括动没有经验数据,即没有历史数据,估算的困难将非常大。 在没有经验作为指导的情况下,惟一的解决办法是做出最好的可能猜测,这种猜测可以利用任何可获得的相关经验。
很显然,一项活动的惟一性越强,其历时估算越不确定,由此在控制中项目的风险也越大。 许多项目(如研究开发项目)都属于这一类,因此那些方法能够降低估算风险的问题也就自然出现了。
正是为了解决该问题,在1957年左右出现了由姜国海军部和Booz,Allcn&Hamilton咨询公司共同开发的PERT技术。 这个概念首先应用在北极星潜艇项目上。
虽然用于CPM项目的活动估算是基于历史数据的平均值。一旦应用,它们被认为或多或少是固定的,或者,以一种通俗的解释来说,它们是“雕刻在岩石上的”。 而PERT系统的基础是假设估算是不确定的,因此谈到的是活动历时的范围和活动历时在该范围的概率,而不是假定该活动将在固定的时间内完成。
摘自《项目经理案头手册》
看别人不顺眼,
是自己修养不够
1楼 帅哥约,不在线,有人找我吗?Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
经验 332点
Re:Pert与CPM的比较(项目管理术语每周一讲) [回复于 2005/2/12]
xiexie
2楼 帅哥约,不在线,有人找我吗?stoneh8
发帖 106篇
注册 2007/3/24
PM币 346
经验 316点
Re:Pert与CPM的比较(项目管理术语每周一讲) [回复于 2005/4/12]
Good translation. Thx.
3楼 帅哥约,不在线,有人找我吗?robinx
发帖 406篇
注册 2005/4/6
PM币 3455
经验 449点
Re:Pert与CPM的比较(项目管理术语每周一讲) [回复于 2005/4/13]
Pert 与CPM最大的不同是历时估算的取值方法不同
看别人不顺眼,
是自己修养不够
4楼 帅哥约,不在线,有人找我吗?Bigpond
来自 四川
发帖 133篇
注册 2003/12/15
PM币 1436
经验 332点
Re:Pert与CPM的比较(项目管理术语每周一讲) [回复于 2005/4/16]
thank
5楼 帅哥约,不在线,有人找我吗?tzhhui
发帖 39篇
注册 2004/4/6
PM币 226
经验 118点
Re:Pert与CPM的比较(项目管理术语每周一讲) [回复于 2007/2/21]
很好
6楼 帅哥约,不在线,有人找我吗?computer4667
来自 山西
注册 2007/2/21
PM币 20
经验 14点
Re:Pert与CPM的比较(项目管理术语每周一讲) [回复于 2007/4/5]
Thanks for your share. And expect much more can be sharing after
7楼 美女约,不在线,有人找我吗?Hmzsusan
发帖 24篇
注册 2007/4/5
经验 70点
Re:Pert与CPM的比较(项目管理术语每周一讲) [回复于 2007/5/26]
thanks a lot
8楼 帅哥约,不在线,有人找我吗?hhcl
发帖 97篇
注册 2006/12/29
PM币 363
经验 160点
