说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
[转帖] 英文案例:Implementing an Enterprise Project [发表于 2004/8/25]
状态 开放帖 精华贴 浏览量 8911
Implementing an Enterprise Project Management Methodology Based on PMI and Best Practices
Description of Client s Business
This company is a large telecom operator in Europe, with more than 4 million clients.
The Client s Challenge
Annually, approximately 900 company employees –– with no common management procedures in place –– were involved in 70 strategic cross-departmental projects. Typically these are large size projects and encompassed several departments simultaneously, such as the implementation of a new accounting system or the set-up of the UMTS network.
As in many other companies, an important percentage of these projects were delivered late and over budget. The client s main objectives were:
• To deliver projects on time, on budget and on scope, and
• To reduce time-to-market by 50%, from 18 to 9 months.
"Each department was managing projects according to its own approach," says Antonio Nieto-Rodriguez, Senior Manager, Project Advisory Services, PricewaterhouseCoopers, Belgium. "There were no clear roles, no responsibility, and no accountability for managing any overall project: scope, time, budget, risk and resources."
_______________
"This was a complex challenge," adds Nieto-Rodriguez. "Revenues were slipping and rapid company growth was compounding the problem. So the clients finally realised they could achieve improvements with a proper company-wide project management methodology. We knew we could help them accomplish their goals. But we saw this challenge as being principally strategic. It would take a major cultural shift to benefit them with ROI and a shorter payback period."
_______________
The PricewaterhouseCoopers Solution
"First, we had to teach these employee managers the methodology," continues Nieto-Rodriguez. "Second, we had to work on the corporate culture change to shift the paradigm, so the Project Managers could change their mentality along with the methodology to match it. They had to be educated on how to work with the procedures, how to behave, and how to think as a project-based organization. This was a critical juncture."
PwC recommended that the engagement consist of seven major steps:
1. Selecting a project management framework: The Project Management Institute s Project Management Body of Knowledge?(PMBOK) was chosen as the foundation of the client s proven methodology for a company-wide plan. This had to be aligned with the organisation s existing best practices in terms of tools, systems and procedures.
"There were several reasons why we choose the PMBOK as the foundation of the methodology, such as: PMI is the leading organisation in development of project management principles and certification standards; it is recognised worldwide as a significant standard for project management knowledge and best practices; it is process oriented and clearly defines the inputs, tools, techniques and outputs for each process," he adds.
2. Conducting two dozen interviews over two weeks to identify major weaknesses between the client s current project management practices and PMI framework. "We found there was no consistency and a severe lack of planning and controlling processes," says Nieto-Rodriguez.
3. Definition of company s project life cycle and customizing of PMI best practices into the client s own project management methodology, consisting of 24 processes and multiple templates.
4. Developing an Intranet-based project management toolkit. "If we wanted people to use the methodology," he adds, "their managers had to have a positive experience with a user-friendly tool. It had to be easy to use, well formatted, and efficient. If not, we knew they d never use it again."
5. Piloting the methodology. "We had to decide which projects we wanted to pilot among the 70 active at that time. We chose a variety of three projects –– a large challenging one, a medium sized one, and a small one. We had a system in place with a coach and a support team for each of the three pilot projects over a two-and-a-half month period."
6. Defining the rollout plan for the implementation of the methodology throughout the first year. PwC inventoried all projects, project managers, teams and departments to train all 900 people in 12 months. "We decided it would be a phased approach. The Project Managers were working on several projects simultaneously. With this approach, we were able to plan the projects and use a coach for each one."
7. Designing and delivering high-level training materials for all company project managers. Over a six- to eight-week period, PwC developed the enterprise-wide training materials. This culminated in a 3-day training program on the new project management methodology.
"We didn t want to train only the project managers, so we spent a half-day with about 650 key project team members, then dedicated another half-day session training the project team s senior managers. This enabled the management to take ownership and responsibility for each project. While we met some reluctance at this senior level, we had obtained full buy-in from the CEO and Senior VP, thus we felt strongly that everybody should know what the methodology was and how to use it."
_______________
Nieto-Rodriguez continues: "During the project, we realised that having the methodology was not enough to achieve the objectives because the team leaders were not ready to support the proposed changes in the project management activities. This is a usual problem: a functional vs. a project-oriented organisation. Therefore, we assisted in the organisational alignment of the company, which consisted in the creation of a project management division, empowerment of project managers, and increased transparency across the lines."
_______________
Benefits/Results to the Client
The total timetable from the start of the project to finish was approximately one year.
Results included:
• Initial benefits from the implementation. The short-term benefits that have been already delivered are mainly qualitative; such as: better business cases, a complete plan for all projects, a more motivated project management group. Quantitative benefits, for instance a reduction of the project life cycle, will be realized within six months to one year. Despite this, PwC persisted on tracking them on a monthly basis.
• Same Project Life Cycle applicable to all the projects. Phases and key milestones were the same for every project. The new project life cycle (PLC) requires the IT and the business people to work together much earlier in the project than before, thus increasing the precision of the business requirements. "In the past, IT would only be consulted once we had the business requirements defined. Today, the new PLC requires that business and IT people sit together from the start of the project. This fact not only increases the accuracy of the requirements, but reduces the time spent and the reworking time during the design and development phases."
• A common company-wide project management language. "Since the launch of the roll-out," he concludes, "we realised the huge benefits of having a common language across the whole company. For example, both management and staff knew what was meant when project managers were referring to the milestones of the project, the work break down structure, and the project life cycle."
楼主 帅哥约,不在线,有人找我吗?轻轻松松
Re:[转帖] 英文案例:Implementing an Enterprise Project [回复于 2004/9/17]
给一下参考的中文,可以?
1楼 帅哥约,不在线,有人找我吗?hulong2004
发帖 230篇
注册 2004/8/26
PM币 327
经验 125点
Re:[转帖] 英文案例:Implementing an Enterprise Project [回复于 2004/10/16]
我有空得时候帮大家翻译一下吧
2楼 帅哥约,不在线,有人找我吗?lcayy
发帖 36篇
注册 2004/10/16
PM币 58
经验 95点
Re:[转帖] 英文案例:Implementing an Enterprise Project [回复于 2004/10/27]
有点看不懂啊!
希望我们能够学的更多,做的更好!
成为最好的项目经理!
学习ing-----------
3楼 帅哥约,不在线,有人找我吗?pm041029
发帖 100篇
注册 2004/10/6
经验 154点
Re:[转帖] 英文案例:Implementing an Enterprise Project [vickyday 修改于 2004/11/23]
基于PMI及其最佳实践,实现企业级项目管理策略
客户业务概述
该公司是一个欧洲的大型电信运营商,有超过400万用户。
客户面临的挑战
每年,公司大约有900个雇员参与到70个战略性跨部门项目,这还不包括常规管理流程。典型说来这些都是大规模项目,并同时涉及多个部门,如,实施一个新的记账系统,或建设UMTS网络。
就像很多其他公司一样,这些项目中的大部分都会推迟交付、超出预算。因此客户的主要目标就是:
——按时、按预算交付项目,并完成既定范围
——把市场响应时间降低50%,从18个月减少到9个月
“每个部门都根据自己的分支在管理项目,”安东尼奥说,他是比利时一家项目顾问服务公司PWC的高级经理。“没有明确的规则、职责、奖惩,任何大项目的管理都这样:范围、进度、预算、风险、资源”
_______________
“这是个错综复杂的难题,”安东尼奥补充说,“年收入渐渐降低,公司的快速发展则使得这个问题变得更加复杂。所以客户最终认识到他们应该通过一个正确的公司级项目管理策略去获得改进。我们知道我们能帮助他们实现目标。但我们把这个难题主要看成战略性问题。这需要企业文化作大的改变,最终使他们在ROI(Return On Invest投资回报率)上收益,并实现更短的回报周期。
_______________
PWC公司建议方案
“首先,我们得教会经理们方法论,”Nieto说,“其次,我们要致力于企业文化变革以实现转换,从而项目经理们能改变他们的观念去适应这个方法论。他们必须受教育,知道如何按规程办事,如何行动,如何按项目型企业思考。这是一个关键的结合点。”
PWC建议从7个主要步骤开始:
1、选择一个项目管理框架:PMI的PMBOK被选定为公司级策划的方法学基础。这必须和企业现有的最佳实践,如工具、系统、规程等协调一致。
“有多个原因促使我们选择了PMBOK作为方法论基础,例如:PMI是项目管理方法和认证标准的领头羊;它在全世界范围内被广泛接受,是项目管理知识及最佳实践的一个重要标准;它是过程导向的,为每个过程都清晰的定义了输入、工具、技巧、输出。”他补充说。
2、在2周内开展2打面谈,以识别客户当前项目管理实践和PMI框架之间的重大弱项。“我们最终发现项目中一致性很缺乏,并且严重缺乏策划和控制流程。”Nieto说。
3、定义公司的项目生命周期流程,并把PMI的最佳实践裁剪成客户自己的项目管理方法,包括24个过程和很多模板。
4、开发一个基于内网的项目管理工具箱。“假如我们希望人们使用这套方法,”他补充道,“他们的经理们就应该能使用一套用户界面友好的工具,并获得良好体验。他应该易于使用,格式精美,有效。假如不是这样,我们相信他们会再也不愿意使用。”
5、部署这套方法。“我们必须决定从当前70多个项目中选择哪些来尝试。最后我们选择了3个项目:一个大规模的极具挑战性,一个中等规模的,和一个小规模的。在2个半月里,对这3个项目,我们有一套支撑体系随时候命,包括一名教练和一个支持组。”
6、制定第一年内方法实施的滚动计划。PwC盘点了所有的项目、项目经理、团队和部门,在12个月内培养了900人次。“我们决定分阶段开展。项目经理们同时会在多个项目中工作。用这种方法,我们能保证对项目进行策划并为每个项目都提供一个教练。”
7、为公司所有的项目经理设计并交付高层培训教材。在一个6~8周的期间内,PWC制定了一个企业级的培训教材。这在新的项目管理方法推动中变成了一个3天的培训课程。
“我们不想只是培训项目经理,所以我们花了半天时间培训了650名关键的项目成员,然后另外半天培训项目团队的高级经理们。这使得管理在每个项目中都占据了主流意识。当我们在这种高级层面碰到一些不情愿时,我们已经获得了CEO和高级VP(副总裁)的完全支持。因此我们坚持每个人都应该知道这种方法论是什么,以及如何使用。”
_______________
Nieto继续说:“在这个项目中,我们意识到光有方法论还不足以实现目标,因为团队的领导们还没准备好支持项目管理活动中提出的这些变革。这是一个很常见的问题,职能型企业VS项目型企业。因此,我们帮助完成了公司的组织机构调整,包括设立一个项目管理部,对项目经理们进行授权,并增加协作流程中的透明度。
_______________
对客户的好处/结果
从开始这个改进项目到结束,总共花了大约1年时间。
结果是:
——实施最初获得的收益:短期的收益主要是定性的。例如,更好的业务案例,所有项目的完整计划,一个更有积极性的项目管理队伍。量化的好处,如缩短项目生命周期,将在6个月到1年内实现。尽管如此,PWC仍然坚持每月进行跟踪。
——所有项目采用相同的项目生命周期:对每个项目都有相同的阶段和关键里程碑。新的项目生命周期PLC要求IT人员和业务部门在项目中更早开始协作,这就增加了业务需求的精确性。如今,新的PLC要求业务部门和IT人员从项目一开始就要坐到一起。这不仅增加了需求的精确性,还减少了设计和开发阶段的返工工作量。”
——一种全公司范围内通用的项目管理语言:“从启动改进活动开始,”他总结说,“我们就认识到了在全公司内拥有一种共同语言所带来的巨大好处。例如,管理层和员工都知道了当项目经理提到项目的里程碑、工作分解结构、项目生命周期时意味着什么。”
C'est La Vie
4楼 美女约,不在线,有人找我吗?vickyday
发帖 32篇
注册 2004/3/20
PM币 140
经验 64点
Re:[转帖] 英文案例:Implementing an Enterprise Project [回复于 2004/11/23]
vickyday, thanks a lot.
5楼 帅哥约,不在线,有人找我吗?轻轻松松
Re:[转帖] 英文案例:Implementing an Enterprise Project [回复于 2004/11/24]
hehe, welcome
If only u would like to find materials for us, I would like to study by translation.
C'est La Vie
6楼 美女约,不在线,有人找我吗?vickyday
发帖 32篇
注册 2004/3/20
PM币 140
经验 64点
Re:[转帖] 英文案例:Implementing an Enterprise Project [回复于 2004/12/3]
Very good!
闲谈莫论人非
 静坐常思已过
7楼 帅哥约,不在线,有人找我吗?sunnyforever
发帖 261篇
注册 2004/9/29
PM币 211
经验 336点
Re:[转帖] 英文案例:Implementing an Enterprise Project [回复于 2005/2/12]
great thanks!
8楼 帅哥约,不在线,有人找我吗?stoneh8
发帖 106篇
注册 2007/3/24
PM币 346
经验 316点
