说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
WBS - The Importance of Being Earnest [发表于 2005/9/25]
状态 开放帖 精华贴 浏览量 5668
by Laurence Nicholson, PMP
One of the biggest challenges faced in the development of accurate and comprehensive project plans is that of scope identification through requirements gathering. All too often this area is subject to a cursory review and not given the level of importance it requires.
Without a fully defined set of requirements, the project scope will be incomplete and the likelihood of controlling the project schedule and cost diminishes.
It is not uncommon to see projects planned without a WBS (Work Breakdown Structure), relying entirely on a Gantt chart constructed by committee. The lack of a comprehensive WBS against which to base cost, schedule and resources is often the root cause of project failure.
It will come as no surprise that this area is the most difficult to enforce, with many clients not understanding the potential dangers of failing to prepare adequately for the management of the project. Experience of a client who refused to write anything down, and categorically refused to sign anything, makes you realise how projects can easily get out of control without a strong PM. In this case, the client’s idea of requirements was a late evening telephone call during which his demands were spelt out, regardless of the fact that he often contradicted previous verbal instructions.
What makes this situation more difficult is often the fact that the Client sponsor is a senior member of the organisation and that they deal with relatively junior team members, which is why the Project Manager should ensure through the communications plan that they are the focal point for information flow in these circumstances.
Consider for a moment the aspects of project planning; scope, time, cost, schedule, resources, HR, risk, quality and procurement. All of these benefit from a defined and detailed breakdown of the project deliverables into work packages against which to estimate the various costs and effort, as well as associate quality criteria for measurement of KPI’s.
Ensuring you build a comprehensive WBS as the foundation for your project management activities will pay dividends when you come to estimate cost and effort, plan resources and track performance. Get it right and down to the right level of detail, and the required controls will be easy to implement, and whilst there is no guarantee of success, the warning signs will be identified earlier in the project for corrective action to be able to take place.
Remember that it is important to decompose the WBS to a suitable level for work packages to be identified. Use the WBS Dictionary to further define the tasks required to be carried out, the resources required to carry them out and the criteria against which each task will be measured from a performance and quality aspect.
At this level the risks associated with the activities planned can be more accurately defined and planned for, improving the management of risk and reducing the impact likelihood. If we could identify and plan for all risks at the start of any project, there would be very few failures, but due to the very nature of risk, there are always ‘unknown unknowns’ that will happen. It is thus important to try to predict as many risks as possible, and doing this at the lowest level of the WBS allows for a greater level of risk management.
Make it habitual to gather your team together from the outset to define the WBS and to estimate at task level, making sure they understand they will be measured at that level.
It has often proven useful in the past to have a brief presentation ready for project stakeholders and sponsors, defining the benefits of accurate requirements gathering and WBS creation, in order to avoid them ‘cutting’ time allotted to this area of project planning.
Create your WBS, decompose to task/activity level and define all relevant details such as effort, cost, quality criteria and relationships. Use this information to control and monitor your project statistics and look forward to a successfully managed project.
楼主 帅哥约,不在线,有人找我吗?轻轻松松
Re:WBS - The Importance of Being Earnest [回复于 2005/9/25]
谢谢!已收藏
1楼 美女约,不在线,有人找我吗?Gress
发帖 443篇
注册 2005/7/31
PM币 2374
经验 636点
Re:WBS - The Importance of Being Earnest [回复于 2005/10/20]
好贴,收藏
2楼 帅哥约,不在线,有人找我吗?freya
发帖 32篇
注册 2005/10/16
PM币 9
经验 37点
Re:WBS - The Importance of Being Earnest [回复于 2005/10/27]
具体的事务同样需要理论的指导,结合实际工作中经验的积累才能不断提升自身的能力。
丹尼斯
3楼 帅哥约,不在线,有人找我吗?schedulecontrol
发帖 19篇
注册 2005/10/26
PM币 105
经验 19点
Re:WBS - The Importance of Being Earnest [回复于 2006/4/5]
学习英语,哈哈!
4楼 美女约,不在线,有人找我吗?gutor
来自 福建
发帖 84篇
注册 2006/4/4
PM币 401
经验 111点
Re:WBS - The Importance of Being Earnest [回复于 2006/4/29]
thank you , this is a good chapter
thank you very much
5楼 帅哥约,不在线,有人找我吗?versage
来自 台湾
发帖 79篇
注册 2006/4/14
PM币 280
经验 172点
Re:WBS - The Importance of Being Earnest [回复于 2006/5/10]
My English is ver poor:(.
Although this chapter is hard to me to understand,I'll try my best to learn
Come on~Come on~hehe
To be a good girl:)
6楼 美女约,不在线,有人找我吗?sues2004
来自 四川
发帖 29篇
注册 2006/5/10
PM币 134
经验 63点
Re:WBS - The Importance of Being Earnest [回复于 2006/12/1]
good
7楼 帅哥约,不在线,有人找我吗?cxd3008
来自 天津
发帖 150篇
注册 2006/11/28
PM币 105
经验 229点
Re:WBS - The Importance of Being Earnest [回复于 2007/12/7]
useful
8楼 帅哥约,不在线,有人找我吗?stonesjz
来自 湖南
发帖 76篇
注册 2007/11/21
PM币 110
经验 101点
