说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
Negotiation success requires planning [发表于 2005/11/27]
状态 开放帖 浏览量 1976
Negotiating is most often learned by the old fashioned "sink or swim" method when the representative for "our side" is told to "go negotiate and do your best". The difficulty with this method is obvious. Any early success will be accidental. Success and failure will produce a pattern of behavior from which the negotiator will learn how to negotiate. Unfortunately, this does not guarantee that the negotiator will have learned the most important or most effective behaviors to ensure continued success.
Learning from others’ experience is an excellent way to increase success on purpose. Ten common problems we have discovered are presented below with suggestions for dealing with them. Because six of these common problems are related to planning, a checklist is presented as a guide for the negotiator. Use of the checklist will help enhance the negotiator’s probability of success.
点击下载该文件
楼主 帅哥约,不在线,有人找我吗?轻轻松松
Re:Negotiation success requires planning [回复于 2005/12/10]
Thank you, Good article!
Email/MSN :lenalee688@hotmail.com
Blog:http://lenaning.mypm.net
1楼 美女约,不在线,有人找我吗?lenaning
发帖 84篇
注册 2005/8/20
PM币 674
经验 230点
