说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
Run a meeting [发表于 2007/6/29]
状态 开放帖 精华贴 浏览量 5514
Meeting needs to be run:
According to my past experience, I found that many person did not know how to host au meeting. I mean the situation that you are the chairperson of the coming meeting. Basically, I think the primary thing to do before meeting is that what the targat of the meeting you are supposed to hold.
As the chairperson, you should be clear about the purposes to host the meeting, which is the start point of the meeting and help you involve in right person. Then, you could figure out a agenda accordingly. Listing topics needed to be discussed in meeting in agenda is helpful to control meeting. You must aware that your purposes will be achieved by going through one topics and working out resutl.with all attendees.
Failed Reasons of meeting:
There are so many failed reasons for one meeting. I find that many failed meetings were because of some little mistakes:
1. Forgetting to inform attendees the meeting time via Email with reminding action, location of the meeting. Sometimes, we always assume every attendees regard the meeting so important as you think and will attend on time. Acutally, that's your personal standpoint. Maybe your meeting is the lower priority for some guys in his rountine task list though the meeting is the hifhest prriority in your tasks list. So, it's better to inform all attendees via Email with reminding fuction as the Meeting Request function in Outlook.
2. No location information in meeting request. Location is also the mostf important information. I am sure most of person have the experience that some one could not find you even though meeting was already started.
3. Meeting time: I have made the mistake because I schedule a meeting at the time I am not supposed to do. The result was that no one attended the meeting except me.
4. Projector: A presentation will help every attendee know your idea clearly and quickly as well as saving time. However, you'd better check whether there is projector in meeting room. Image what will happen if a soldier have enough bullets but forget to take gun with him. I think the only thing he can do is to throw bullets to enemy and beg for god hopefully.
5. Meeting minutes: Meeting minutes is the workout of the meeting anfd in which all of topics discussed should be recorded. For each topics, action plan should be included. It's better forward meeting minutes to all of meeting attendees and let them feed back according to see whether anything is missed in meeting minutes. Do remember add following information in your meeting minutes:
If anything missed please let me know. This is helpful to avoid argument as a evidence.
6. Others...... and to be continued
楼主 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:Run a meeting [回复于 2007/7/2]
thank you for sharing~~~~
1楼 帅哥约,不在线,有人找我吗?ycheng30
来自 福建
发帖 178篇
注册 2007/6/30
PM币 510
经验 192点
Re:Run a meeting [回复于 2007/7/4]
Ths
2楼 帅哥约,不在线,有人找我吗?maomao1989
发帖 595篇
注册 2007/1/6
PM币 1217
经验 1594点
Re:Run a meeting [回复于 2007/7/17]
Thanks!
But actually I get to know all of what you advise, but in the actual meeting , I always forgot some of them.
So I'd like to have a assistant to help me make the records and remind me the meeting schedule. And then ask every attendee sign his name, then scan the record and send it to them. Don't forget to backup one for reminding. If anyone don't remember and agree the conclusion of the meeting and refuse to perform as the conclusion, you can ask him to review the scan document of the meeting record.
学习—改善—创新
3楼 帅哥约,不在线,有人找我吗?jerrychen
发帖 11篇
注册 2007/7/17
PM币 70
经验 19点
Re:Run a meeting [回复于 2007/7/22]
Yes, I agree with the guy from upstairs friend.
4楼 帅哥约,不在线,有人找我吗?pm-yao
来自 安徽
发帖 233篇
注册 2007/6/5
PM币 498
经验 489点
There is a dedicated role to own the meeting minutes and often is the responsibility of Project manager who reports to Program manager.
Actually, project manager are recording meeting minutes in meeting and summarize them at the end of meeting to clarify the content to attendees. The meeting minutes is following the content of meeting agenda distributed to invited attendees before meeting.
I don't think the activity will cost of more time.
5楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:Run a meeting [回复于 2009/9/18]
ding
6楼 帅哥约,不在线,有人找我吗?yg
发帖 456篇
注册 2009/9/17
PM币 12
经验 467点
Re:Run a meeting [回复于 2011/1/31]
thank for your sharing
7楼 帅哥约,不在线,有人找我吗?mike.lee
发帖 55篇
注册 2004/7/21
PM币 170
经验 137点
Re:Run a meeting [回复于 2011/2/17]
thank you for your share. don't forget to define the responsible person and deadline for each action in the meeting minutes, otherwise, the open point may be still open after the meeting.
8楼 美女约,不在线,有人找我吗?sure2010
发帖 27篇
注册 2010/10/8
PM币 48
经验 74点
