说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
我相信你有时候忘记戴“绿帽子”了 [wml 修改于 2007/8/7]
状态 开放帖 精华贴 浏览量 2994
经过长时间的思考,我总结了一句话:
在工作中,我们要时时记着带绿帽子,在生活着能给别人带绿帽子就不要放过。
旁边有位客观就问了:
“我就纳闷,都是绿帽子,差距咋就这么大涅?”
先看工作中的“绿帽子”:
作为manager,经常要进行决策,但是如何决策才可得到最佳的结论?
在Edward de Bono的“六个思考的帽子”中提到:善用六顶思考的帽子,就可以帮助你做出最佳选择,这六顶帽子是:
* White Hat:(决策的基础,历史的数据)
With this thinking hat you focus on the data available. Look at the information you have, and see what you can learn from it. Look for gaps in your knowledge, and either try to fill them or take account of them.
This is where you analyze past trends, and try to extrapolate from historical data.
* Red Hat(直觉判断):
'Wearing' the red hat, you look at problems using intuition, gut reaction, and emotion. Also try to think how other people will react emotionally. Try to understand the responses of people who do not fully know your reasoning.
* Black Hat(风险分析及对策):
Using black hat thinking, look at all the bad points of the decision. Look at it cautiously and defensively. Try to see why it might not work. This is important because it highlights the weak points in a plan(突出了计划中最薄弱的地方). It allows you to eliminate them, alter them, or prepare contingency plans to counter them.
Black Hat thinking helps to make your plans 'tougher' and more resilient(有弹性). It can also help you to spot fatal flaws(致命的缺陷) and risks before you embark on a course of action. Black Hat thinking is one of the real benefits of this technique, as many successful people get so used to thinking positively that often they cannot see problems in advance. This leaves them under-prepared for difficulties.
Yellow Hat(乐观预期):
The yellow hat helps you to think positively. It is the optimistic viewpoint that helps you to see all the benefits of the decision and the value in it. Yellow Hat thinking helps you to keep going when everything looks gloomy and difficult.
* Green Hat(这就是著名的绿帽子):
The Green Hat stands for creativity. This is where you can develop creative solutions to a problem. It is a freewheeling way of thinking, in which there is little criticism of ideas. A whole range of creativity tools can help you here.
(绿帽子代表创造力。据此你可以针对问题提出创造性的解决方案。这是一种发散思维的方法,不带有指责性的想法。)
* Blue Hat(权衡控制):
The Blue Hat stands for process control. This is the hat worn by people chairing meetings. When running into difficulties because ideas are running dry, they may direct activity into Green Hat thinking. When contingency( 意外事故) plans are needed, they will ask for Black Hat thinking, etc.
其中绿帽子的意思是,要有创造性,看看是否还有其他更好的方法解决问题。不要墨守常规,错过最佳选择。关于这方面的论述可以参考以下的link:
http://www.mindtools.com/pages/article/newTED_07.htm
在这里你可以下载一个PDF,它是一个worksheet to help you make decision.
在mypm论坛资料库中,可以下载到“六项思考的帽子”中文版。
我读完之后,不由得仰天长啸:
“作为一个项目经理或者任何manager, 要牢记戴着绿帽子。”
因此每天下班 前,要问问自己:“今天,我带绿帽子了吗?”
至于生活中的绿帽子,我这里就不详谈了,如果要谈,需要坐在高高的草堆上,看着月亮在云朵里穿行,听我讲绿帽子的故事。。。。。
楼主 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:我相信你有时候忘记戴“绿帽子”了 [回复于 2007/8/8]
太好了,我一定会记住的谢谢了!
我相信我是最棒的!
1楼 帅哥约,不在线,有人找我吗?13502007502
来自 天津
发帖 85篇
注册 2007/8/8
PM币 656
经验 405点
无法下载啊!能发一份给我吗?谢谢!Fuller0414@163.com
2楼 帅哥约,不在线,有人找我吗?100004
来自 辽宁
发帖 186篇
注册 2005/3/29
PM币 3
经验 408点
100004 在 2007-8-8 10:29:19 发表的内容
抱歉,我也没有。你可以google找,到处都是
3楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Wonderful~!~ I learnd it ~!~ Thank you ~!~
4楼 美女约,不在线,有人找我吗?shelly626
来自 四川
发帖 9篇
注册 2005/10/31
PM币 55
经验 13点
Re:我相信你有时候忘记戴“绿帽子”了 [回复于 2007/8/9]
yun
5楼 帅哥约,不在线,有人找我吗?msn4848
来自 海南
发帖 8篇
注册 2005/9/28
PM币 5
经验 15点
很好,有用
6楼 美女约,不在线,有人找我吗?2004591102
发帖 171篇
注册 2007/6/7
经验 348点
