说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
解决原油短缺的最伟大的solution [发表于 2007/8/12]
状态 开放帖 浏览量 1499
在地理学课上,老师告诉我们很久以前地球上到处都是恐龙,恐龙死后就变成石油。所以美国的科学家可以克隆恐龙,就像《侏罗纪公园》里面那样。这样,世界上就会有新的石油能源。
这样的话,就不会因为石油危机造成侵略战争,这样也就解决了中东问题。从而达到一箭双雕的目的。
但是美帝国主义和儿童杀手布什是不会这样做的。。。。
She does so by solving the world oil supply problem in one single fell swoop of logic and progressive thinking you'd never see the criminal mental retard Bush and his criminal clique of criminal hawkish warmongering US imperialist war-crazed capitalists display. Of
course, the criminal Bush and the criminal capitalist oil industry of Halliburton will never let that happen.
And here is Juche Girl's brilliant solution --
I think I may have a solution to the world oil supply crisis.
In geography class our teachers taught us that a long time ago dinosaurs roamed the Earth. Then they died and melted, turning into oil (the dinosaurs, not the teachers, obviously). So to resolve the problem of dwindling oil supply, scientists in America could clone dinosaurs (like it was done in the movie "Jurassic Park") and then the world would have a renewable supply for ever.
Then with the oil crisis solved the need for wars of invasion would no longer be required, ensuring peace in the Middle East. That would be like solving two problems at once. ^_^
Of course, US capitalist oil industry and Bush killer of children don't want that...
I don't think we can compete with this sort of logic ...
Here the link:
http://www.rantburg.com/poparticle.php?ID=128315&D=2005-09-01&;HC=4
楼主 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:解决原油短缺的最伟大的solution [回复于 2007/8/25]
为了饲养这些恐龙,需要消耗更多的石油,嘿嘿~
1楼 帅哥约,不在线,有人找我吗?swf310
来自 福建
发帖 73篇
注册 2007/8/25
PM币 15
经验 105点
Re:解决原油短缺的最伟大的solution [回复于 2009/9/18]
ding
2楼 帅哥约,不在线,有人找我吗?yg
发帖 456篇
注册 2009/9/17
PM币 12
经验 467点
