说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
Trends in Project Management [发表于 2008/1/30]
状态 开放帖 精华贴 浏览量 2245
本文全文见联盟网站文库,链接为: http://www.mypm.net/articles/show_article_content.asp?articleID=12557
以下为部分内容:
Johnson .Wang
Trend (1): From standardization to change
All the ORGS are used to and are trying to standardize their management system, which does not contain systematically how to manage changes.
Due to the changes are in various forms, different sizes and complex links with the ORGS, PMI uses the word “body of knowledge” to cover all the knowledge necessary , IPMA choose the word “competence” to describe the ability , OGC&APM says “methodology”  to guide step by step, in order to make the changes into reality successfully。
Trend (2) from project management to program management
PMI: The new Program Management Professional (PgMP) credential has been announced by the Project Management Institute (PMI®). It will be PMI’s first credential designed to demonstrate both project and program management skills(2007)
 a
(The bar chart by Mr. Max. Wideman)
Trend (3) From Generalization to Localization
  This trend is by guessing with limited clues, like credential in construction area, training needs in specialty
Chinese government office replaced the old credential “construction manager” by several new ones, but the new credentials are still in construction domain instead of generalization domain.
The arguments of trend (3):
1. Generalization is the advantage and disadvantage of the BOKS
2. Any methodology comes from the practice and to be applied to the practice, the nearer to the practice, the more value it brings.
3. Certified by the BOKS may or may not have the ability to manage a project, or the certifications are less relevance with the knowledge and the ability in specialty
4. The ORGS in China are overwhelmingly asking project training courses in their related business domain instead of “generally speaking”, which is the situation in 2000.
5. Projects in all the ORGS are quite different in sizes, contents, characters, and processes, which should be managed with different methodology and requires different professional ability (Credential & training)
6. Trend (3) will add value to project management in ORGS.
E-mail:yhua@mypm.net
楼主 帅哥约,不在线,有人找我吗?bjyr
发帖 3910篇
PM币 268
经验 8359点
Re:Trends in Project Management [回复于 2008/1/30]
It seems an interesting topics and to be more interesting if more information provided.
With regard to point 2, there are many companies making use of that as such trend. And there has two levels Plan:
1. High level: A plan which is seldom updated to control key milestones for program
2. Detailed level: A monthly plan or weekly plan to control execution and alway been updated.
3. Involve Marketing, Manufacturing, services in more than before.
1楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
