说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
经理与工程师 [发表于 2009/1/13]
状态 开放帖 浏览量 3246
A man in a hot air balloon realized he was lost. He reduced altitude and spotted a woman below. He descended a bit more and shouted, "Excuse me, can you help me? I promised a friend I would meet him an hour ago, but I don't know where I am."
The woman below replied, "You're in a hot air balloon hovering approximately 30 feet above the ground. You're between 40 and 41 degrees north latitude and between 59 and 60 degrees west longitude."
"You must be an engineer," said the balloonist.
"I am," replied the woman, "How did you know?"
"Well," answered the balloonist, "everything you told me is, technically correct, but I've no idea what to make of your information, and the fact is I'm still lost. Frankly, you've not been much help at all. If anything, you've delayed my trip."
The woman below responded, "You must be in Senior Management."
"I am," replied the balloonist, "but how did you know?"
"Well," said the woman, "you don't know where you are or where you're going. You have risen to where you are due to a large quantity of hot air. You made a promise, which you've no idea how to keep, and you expect people beneath you to solve your problems. The fact is you are in exactly the same position you were in before we met, but now, somehow, it's my fault."
楼主 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:经理与工程师(故事梗概) [回复于 2009/1/13]
一个经理趁热气球会朋友的时候迷路了,然后问下面的一个女工工程师自己目前的位置,女工工程师非常专业的用数字描述了经理当前的位置。
经理说:“你一定是工程师,因为你告诉我的信息从技术上来说是准确的,但却不能利用你的信息做出任何判断”
工程师说:“你一定是资深管理者,因为你不知道你现在在那里或者要去那里,你坐的那魔高,你与别人约定好了但却不能做到,你期望你下面的人帮你解决出现的问题。事实上你目前的位置没有变化。但是现在,从某些方面说,是我的错”
1楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:经理与工程师 [回复于 2010/8/23]
很有意思的一篇文章
2楼 帅哥约,不在线,有人找我吗?xieyue1975
发帖 98篇
注册 2010/2/8
PM币 121
经验 187点
Re:经理与工程师 [回复于 2010/9/16]
值得思考
3楼 帅哥约,不在线,有人找我吗?lidawei43
发帖 446篇
注册 2009/4/1
PM币 101
经验 820点
Re:经理与工程师 [回复于 2011/12/6]
不错。
4楼 美女约,不在线,有人找我吗?Karidafan
发帖 35篇
注册 2011/12/2
PM币 6
经验 68点
