说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
挣值管理EVM [wml 修改于 2009/3/23]
状态 开放帖 浏览量 4142
该帖子同步发自圈子:实战 (访问该圈子)
(多次尝试,资料无法上传)
挣值的概念:
Earned Value Management.挣值被称为:“management with the lights on”,因为EVM能够清晰客观的描述:与计划比较,目前项目的状态如何。
这个状态有两个方面:
1.目前项目是怎么一个状况
where a project is and
2.目前项目进行的如何
where it is going
比较的基准是:
1.as compared to where it was supposed to be
2. and where it was supposed to be going
EVM的特点或者好处:
EVM uses the
fundamental principle that patterns and trends in the past can be good predictors of
the future
原文:
1.1 THE ROLE OF EARNED VALUE MANAGEMENT
Feedback is critical to the success of any project. Timely and targeted feedback can
enable project managers to identify problems early and make adjustments that can
keep a project on time and on budget.
Earned Value Management (EVM) has proven itself to be one of the most effective
performance measurement and feedback tools for managing projects. It enables managers
to close the loop in the plan-do-check-act management cycle.
EVM has been called ‘‘management with the lights on’’ because it can help clearly
and objectively illuminate where a project is and where it is going—as compared to
where it was supposed to be and where it was supposed to be going. EVM uses the
the future.
EVM provides organizations with the methodology needed to integrate the management
of project scope, schedule, and cost. EVM can play a crucial role in answering
management questions that are critical to the success of every project, such as:
● Are we ahead of or behind schedule?
● How efficiently are we using our time?
● When is the project likely to be completed?
● Are we currently under or over our budget?
● How efficiently are we using our resources?
● What is the remaining work likely to cost?
● What is the entire project likely to cost?
● How much will we be under or over budget at the end?
If the application of EVM to a project reveals that the project is behind schedule
or over budget, the project manager can use the EVM methodology to help identify:
● Where problems are occurring
● Whether the problems are critical or not
● What it will take to get the project back on track.
楼主 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:挣值管理EVM [回复于 2009/9/18]
ding
1楼 帅哥约,不在线,有人找我吗?yg
发帖 456篇
注册 2009/9/17
PM币 12
经验 467点
