说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
挣值管理EVM2:关键 [发表于 2009/3/23]
状态 开放帖 浏览量 4109
该帖子同步发自圈子:实战 (访问该圈子)
In summary, EVM strategically augments good project management to facilitate
the planning and control of cost and schedule performance. The key practices of
EVM include:
● Establish a performance measurement baseline (PMB)
 Decompose work scope to a manageable level
 Assign unambiguous management responsibility
 Develop a time-phased budget for each work task
 Sel-ect EV measurement techniques for all tasks
 Maintain integrity of PMB throughout the project.
● Measure and analyze performance against the baseline
 Record resource usage during project exe-cution
 Objectively measure the physical work progress
 Credit EV according to EV techniques
 Analyze and foreca-st cost/schedule performance
 Report performance problems and/or take action.
楼主 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:挣值管理EVM2:关键 [wml 修改于 2009/3/23]
为了贴这段英文,我反复了三次,因为下面三个单词是被通用注入限制的:
s e l e c t
E x e c u t i o n
F o r c a s t
坛主,我不的不语重心长的再次提出建议,如果这个发贴功能不能尽快解决,真的这个论坛显得很挫!
不是我在这里臭摆,很多英文资料真的不错,很值得看看。
1楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Earned Value Management (EVM) relies on three key
data points:
● Planned Value
PV是你打算花费的资源,主要基于甘特图。
比如你在第一个月打算花100元
第二个月100元
第三个月150元
那么:
第一个月的PV是:100
第二个月的PV是:200 (第一个月的预算100加上第二个月的100)
第三个月的PV是:450(第一个月的预算100加上第二个月的100再加上第三个月的150)
● Earned Value
● Actual Cost
2楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
DESCRIPTIONS OF THE BASIC EVM ELEMENTS [回复于 2009/3/23]
Planned Value
Planned Value (PV) describes how far along project work is supposed to be at any
given point in the project schedule. It is a numeric reflection of the budgeted work
that is scheduled to be performed, and it is the established baseline (also known as
the performance measurement baseline, or PMB) against which the actual progress
of the project is measured. Once established, this baseline may only change to reflect
cost and schedule changes necessitated by changes in the scope of work. Also known
as the Budgeted Cost of Work Scheduled (BCWS), Planned Value is usually cha-rted
showing the cumulative resources budgeted across the project schedule. Figure 2-1
shows the Planned Value S-Curve for Project EZ.
3楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Earned Value [回复于 2009/3/23]
Earned Value
Earned Value (EV) is a snapshot of work progress at a given point in time. Also known
as the Budgeted Cost of Work Performed (BCWP), it reflects the amount of work that
has actually been accomplished to date (or in a given time period), expressed as the
planned value for that work. Figure 2-2 shows the Earned Value for Project EZ at the
four-month mark, and indicates that less work than planned has been accomplished
没办法贴不了图,大家自己去猜到底是怎么样。
4楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Actual Cost [回复于 2009/3/23]
Actual Cost
Actual Cost (AC), also known as the Actual Cost of Work Performed (ACWP), is an
indication of the level of resources that have been expended to achieve the actual
work performed to date (or in a given time period). Figure 2-3 shows the Actual Cost
for Project EZ at the four-month mark, and indicates that the organization has spent
less than it planned to spend to achieve the work performed to date.
5楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
