说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
面对面的沟通是不是总是最有效? [发表于 2009/5/23]
状态 开放帖 浏览量 17077
该帖子同步发自圈子:实战 (访问该圈子)
Is Face-to-Face Communication Always the Way to Go?
http://blog.guykawasaki.com/pitching_presenting_and_speaking/
A common assumption is that communicating face-to-face is more persuasive than email. That's not always true, according to a 2002 study. Researchers found that men are often more responsive to email because it downplays their competitive tendencies. On the other hand, women react better to in-person enco-unters because they are more relationship-oriented.
These same researchers found that someone will help another person if they feel a high level of "oneness" with the person--that is, the extent to which they indentify with the other person. When the oneness was low between men, email was much more effective. When the oneness was high for women, face-to-face interactions were much better.
Whether pitching an idea, working with a new client, or finding a job, we often have to take risks and reach out to people we don't know. We don't want to perpetuate gender stereotypes, but this research is useful to keep in mind as we make those cold calls. Based on what we know about the person, does email or face-to-face interaction make more sense? Face-to-face isn't always the answer.
楼主 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:面对面的沟通是不是总是最有效? [回复于 2009/5/23]
oneness ['wʌnnis]
n. 单一性,同一性,统一性
本文中可能值男银的面子得到了满足。
downplay ['daʊnplei]
v. 不予重视
本文可能指降低,去少的意思。
downplay their competitive tendencies. 背后的意思是,男人都是好斗的,要面子的。
1楼 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:面对面的沟通是不是总是最有效? [回复于 2009/5/24]
learned! thanks
2楼 帅哥约,不在线,有人找我吗?occupation2008
来自 河北省
发帖 499篇
注册 2009/2/9
PM币 239
经验 806点
Re:面对面的沟通是不是总是最有效? [回复于 2017/8/17]
学习了
3楼 帅哥约,不在线,有人找我吗?tonyjiaqi
发帖 121篇
注册 2017/7/11
PM币 763
经验 571点
