说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
项目完成时 [发表于 2009/6/10]
状态 开放帖 浏览量 1802
本文全文见联盟网站文库,链接为: http://www.mypm.net/articles/show_article_content.asp?articleID=15488
以下为部分内容:
Organization and Completeness
 Are all internal cross-references to other requirements correct?
 Are all requirements written at a consistent and appropriate level of detail?
 Do the requirements provide an adequate basis for design?
 Is the implementation priority of each requirement included?
 Are all external hardware, software, and communication interfaces defined?
 Have algorithms intrinsic to the functional requirements been defined?
 Does the SRS include all of the known customer or system needs?
 Is any necessary information missing from a requirement? If so, is it identified as TBD?
 Is the expected behavior documented for all anticipated error conditions?
Correctness
 Do any requirements conflict with or duplicate other requirements?
 Is each requirement written in clear, concise, unambiguous language?
 Is each requirement verifiable by testing, demonstration, review, or analysis?
 Is each requirement in scope for the project?
 Is each requirement free from content and grammatical errors?
 Can all of the requirements be implemented within known constraints?
 Are any specified error messages unique and meaningful?
Quality Attributes
 Are all performance objectives properly specified?
 Are all security and safety considerations properly specified?
 Are other pertinent quality attribute goals explicitly documented and quantified, with the acceptable tradeoffs specified?
Traceability
 Is each requirement uniquely and correctly identified?
 Is each software functional requirement traceable to a higher-level requirement (e.g., system requirement, use case)?
Special Issues
 Are all requirements actually requirements, not design or implementation solutions?
 Are the time-critical functions identified, and timing criteria specified for them?
 Have internationalization issues been adequately addressed?
楼主 帅哥约,不在线,有人找我吗?mosquitowzw
来自 福建省
注册 2009/6/4
PM币 152
经验 35点
