说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
绿霸-密西根大学分析报告 [发表于 2009/6/12]
状态 开放帖 浏览量 3321
该帖子同步发自圈子:实战 (访问该圈子)
http://www.cse.umich.edu/~jhalderm/pub/gd/
Conclusion
Our brief testing proves that Green Dam contains very serious security vulnerabilities. Unfortunately, these problems seem to reflect systemic flaws in the code. The software makes extensive use of programming techniques that are known to be unsafe, such as deprecated C string processing functions including sprintf and fscanf. These problems are compounded by the design of the program, which creates a large attack surface: since Green Dam filters and processes all Internet traffic, large parts of its code are exposed to attack.
If Green Dam is deployed in its current form, it will significantly weaken China's computer security. While the flaws we discovered can be quickly patched, correcting all the problems in the Green Dam software will likely require extensive rewriting and thorough testing. This will be difficult to achieve before China's July 1 deadline for deploying Green Dam nationwide.
楼主 帅哥约,不在线,有人找我吗?wml
发帖 2621篇
注册 2004/8/5
PM币 1819
经验 6249点
Re:绿霸-密西根大学分析报告 [回复于 2009/6/17]
1楼 帅哥约,不在线,有人找我吗?xiongke168
发帖 0篇
注册 2009/6/17
经验 39点
