说明:英语是基本功
轻轻松松
登录:2009/1/22
次数:662
注册:2004/7/17
发帖:1900
Bigpond
登录:2010/8/1
次数:190
注册:2003/12/15
发帖:133
wml
登录:2013/9/10
次数:2393
注册:2004/8/5
发帖:2621
积极看待每一天 [发表于 2010/5/19]
状态 开放帖 浏览量 3205
该帖子同步发自:(天涯的博客  访问该博客)
If your life feels like it is lacking the power that you want and the motivation that you need, sometimes all you have to do is shift your point of view.
如果你觉得心有余力不足,觉得缺乏前进的动力,有时候你只需要改变思维的角度。
By training your thoughts to concentrate on the bright side of things, you are more likely to have the incentive to follow through on your goals. You are less likely to be held back by negative ideas that might limit your performance.
试着训练自己的思想朝好的一面看,这样你就会汲取实现目标的动力,而不会因为消极沉沦停滞不前。
Your life can be enhanced, and your happiness enriched, when you choose to change your perspective. Don't leave your future to chance, or wait for things to get better mysteriously on their own. You must go in the direction of your hopes and aspirations. Begin to build your confidence, and work through problems rather than avoid them. Remember that power is not necessarily control over situations, but the ability to deal with whatever comes your way.
一旦变换看问题的角度,你的生活会豁然开朗,幸福快乐会接踵而来。别交出掌握命运的主动权,也别指望局面会不可思议的好转。你必须与内心希望与热情步调一致。建立自信,敢于与困难短兵相接,而非绕道而行。记住,力量不是驾驭局势的法宝,无坚不摧的能力才是最重要的。
Always believe that good things are possible, and remember that mistakes can be lessons that lead to discoveries. Take your fear and transform it into trust; learn to rise above anxiety and doubt. Turn your "worry hours" into "productive hours". Take the energy that you have wasted and direct it toward every worthwhile effort that you can be involved in. You will see beautiful things happen when you allow yourself to experience the joys of life. You will find happiness when you addopt positive thinking into your daily routine and make it an important part of your world.
请坚信,美好的降临并非不可能,失误也许是成功的前奏。将惶恐化作信任,学会超越担忧和疑虑。让“诚惶诚恐”的时光变得“富有成效”。不要挥霍浪费精力,将它投到有意义的事情中去。当你下意识品尝生命的欢愉时,美好就会出现。当你积极地看待生活,并以此作为你的日常准则时,你就会找到快乐的真谛。
楼主 帅哥约,不在线,有人找我吗?天涯
来自 黑龙江省
发帖 15篇
注册 2010/5/19
PM币 85
经验 55点
Re:积极看待每一天 [回复于 2011/2/12]
认同!大彻大悟!
1楼 美女约,不在线,有人找我吗?honeydawn
发帖 11篇
注册 2011/2/12
经验 22点
Re:积极看待每一天 [回复于 2011/3/2]
2楼 美女约,不在线,有人找我吗?小小芹菜919
注册 2011/3/2
PM币 8
经验 13点
Re:积极看待每一天 [回复于 2011/6/30]
make sense
3楼 帅哥约,不在线,有人找我吗?wlx622
发帖 101篇
注册 2010/6/20
PM币 40
经验 258点
Re:积极看待每一天 [回复于 2014/2/10]
great.It is very useful
4楼 美女约,不在线,有人找我吗?339366535
注册 2014/2/10
PM币 14
经验 17点
