PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
6月26日的一道考题 [发表于 2010/7/1]
状态 开放帖 浏览量 1571
你处在活动顺序设定的环节,有一个活动需要的技术项目里所有的成员都不知道,这个特殊的活动和其他的活动的关系是什么
A.hard logic
B.soft logic
C.外部logic
D.记不住了
这道题选什么啊???
楼主 帅哥约,不在线,有人找我吗?ritouhou
来自 山西省
发帖 14篇
注册 2010/7/1
PM币 11
经验 33点
Re:6月26日的一道考题 [回复于 2010/7/1]
没有知道的么?
1楼 帅哥约,不在线,有人找我吗?ritouhou
来自 山西省
发帖 14篇
注册 2010/7/1
PM币 11
经验 33点
再顶顶,希望会的人给解答
2楼 帅哥约,不在线,有人找我吗?ritouhou
来自 山西省
发帖 14篇
注册 2010/7/1
PM币 11
经验 33点
Re:6月26日的一道考题 [wanghongbo68 修改于 2010/7/1]
正确答案是B。
根据PMI对hard logic\soft logic\external logical的解释,项目组成员缺少某种技术,一定不属于hard logic\external logical,与soft logic 的意思比较接近,同时,缺少某种技术可以通过多种方式如学习、培训和招聘等方式来解决,因此选项B较贴近。
关于选项A\B\C的具体解释,请参见PMBOK2008英文版 P139-140 或参见下文:
.2 Dependency Determination
Three types of dependencies are used to define the sequence among the activities:
•mandatory dependencies. Mandatory dependencies are those that are contractually required
or inherent in the nature of the work. The project team determines which dependencies are
mandatory during the process of sequencing the activities. Mandatory dependencies often
involve physical limitations, such as on a construction project where it is impossible to erect
the superstructure until after the foundation has been built, or on an electronics project, where
a prototype must be built before it can be tested. Mandatory dependencies are also sometimes
referred to as hard logic.
•Discretionary dependencies. The project team determines which dependencies are
discretionary during the process of sequencing the activities. Discretionary dependencies
are sometimes referred to as preferred logic, preferential logic, or soft logic. Discretionary
dependencies are established based on knowledge of best practices within a particular
application area or some unusual aspect of the project where a specific sequence is desired,
even though there may be other acceptable sequences. Discretionary dependencies should be
fully documented since they can create arbitrary total float values and can limit later scheduling
options. When fast tracking techniques are employed, these discretionary dependencies should
be reviewed and considered for modification or removal.
• External dependencies. The project management team determines which dependencies
are external during the process of sequencing the activities. External dependencies involve a
relationship between project activities and non-project activities. These dependencies are usually
outside the project team’s control. For example, the testing activity in a software project can be
dependent on the delivery of hardware from an external source, or governmental environmental
hearings may need to be held before site preparation can begin on a construction project.
3楼 帅哥约,不在线,有人找我吗?wanghongbo68
发帖 40篇
注册 2010/1/23
PM币 73
经验 84点
谢谢你的回答,但是如果这个技术经过调查,发现是另一个活动开始的必要条件的时候,就会变成hard logic,所以,我很纠结。。。。。
4楼 帅哥约,不在线,有人找我吗?ritouhou
来自 山西省
发帖 14篇
注册 2010/7/1
PM币 11
经验 33点
PMI的题目不要去推敲它,如果仔细推敲大部分题都有问题。
只要看表面意思就对了,同时,看到题目后,一定要找到此题的焦点。如果找不到焦点,想做对就很困难了。
5楼 帅哥约,不在线,有人找我吗?wanghongbo68
发帖 40篇
注册 2010/1/23
PM币 73
经验 84点
我个人觉得应该是C,外部依赖,因为团队成员都不知道,只能依赖外面的信息.
6楼 帅哥约,不在线,有人找我吗?PMP2002
发帖 3424篇
PM币 43
经验 7462点
外部依赖要根据PMI的定义。
External dependencies involve a relationship between project activities and non-project activities. These dependencies are usually outside the project team’s control. For example, the testing activity in a software project can be dependent on the delivery of hardware from an external source, or governmental environmental hearings may need to be held before site preparation can begin on a construction project.
7楼 帅哥约,不在线,有人找我吗?wanghongbo68
发帖 40篇
注册 2010/1/23
PM币 73
经验 84点
Re:6月26日的一道考题 [回复于 2010/7/11]
学习
8楼 帅哥约,不在线,有人找我吗?奔驰的蜗牛
发帖 118篇
注册 2010/7/11
PM币 19
经验 123点
