PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
PMP考试的19个窍门(转) [发表于 2010/9/3]
状态 开放帖 精华贴 浏览量 27649
1.The Examination process can be very stressful. Try these stress reduction suggestions: Arrive well-nourished … and bring snacks. Dress comfortably. Drive to the testing center a few days before the Exam so you know the route. See if you can tour the testing center when you make your dry run. This will help acclimate you to the testing environs before test day.
2.Many Exam questions put you in a hypothetical situation and ask you for the best solution. These type questions can be tricky. Take your time, read the question twice and make sure you fully understand what the question is asking before you attempt to answer.
3.When taking the Exam, you will be allotted a little more than one- minute per question. Pace yourself to answer around fifty questions per hour. Plan to use the full four hours. There is no need to rush or virtue in finishing early. It is best to be thorough.
4.The Exam questions are tough by anyone’s standards. Do not approach them lightly. While taking the Exam, you must focus all of your attention and energy. Practice some deep- breathing and mental-readiness exercises beforehand. Without proper focus, you can easily find yourself off-pace, anxious and making simple mistakes. You should also be aware that constant focus can be draining. You should plan to take a ten-minute break each hour to recha rge.
5.On some Exam questions, all four answer options are correct statements. However, three will have little or no bearing to the particular question. This is often disorienting. PMI does this by design to help ensure a thorough understanding of the subject matter. Beware.
6.You will be supplied with scratch paper and pencils at the testing center. Before you begin the Exam, take ten or fifteen minutes to write down all of your memorized equations, key definitions and other acronyms. This will reduce anxiety and provide you with a handy (and legal) reference throughout the Exam.
7.It is a good idea to track your progress while taking the Exam. On your scratch paper, track each question as you answer. Make three columns. In the first column, place a check mark each time you answer a question correctly with 100% certainty. The second column is for those questions you were able to narrow down to two possible correct answers. The third column is for those questions you answered with mere guesses. When you complete all 200 Exam questions, add up the check marks in your first column and multiply the total by 0.9. Multiply the total check marks from your second column by 0.5. Multiply the total from your third column by 0.25. Now add the three products to derive your probable score. This process usually produces a very accurate estimate of your actual score. You need 137 to pass. If your probable score is close to 137 you should revisit all questions from columns two and three. You can change your answers anytime before declaring you are done. If your probable score is well above 137, you can decl are victory and “pass-in” your Exam with confidence. The Exam is scored for you immediately by testing center personnel.
8.Once you understand what the Exam question is asking, try to determine the best answer before you look at the four options. Then be sure to read all four options.
9.Recurring PMP Exam theme ¬ “Projects must be strategically aligned with the high-level strategic objectives of the performing organization.”
10.Recurring PMP Exam theme ¬ “The Work Breakdown Structure (WBS) forms the basis of all estimating and project planning. The WBS is all-important”
11.Recurring PMP Exam theme …“Project Managers should spend 90% of their time communicating.”
12.Recurring PMP Exam theme …“Planning is the most important of all the Project Management processes”
13.Recurring PMP Exam theme … “The Project Team must be involved early in the lanning process and in all major decisions. The Project Team is all-important.”
14.Recurring PMP Exam theme …“Lessons Learned and Historical Records are essential inputs to just about every Project Management process.”
15.Recurring PMP Exam theme …“Project Managers are all-important and have complete authority and responsibility for all aspects of a Project.”
16.Recurring PMP Exam theme …“Project Stakeholders and their needs/expectations are all-important.”
17.Recurring PMP Exam theme …“Administrative closure and Scope Verification are essential considerations with just about every project deliverable.”
18.Recurring PMP Exam theme …“Adding out-of-scope extras to please project stakeholders is tempting . However, this practice adds no value and is generally discouraged.”
19.Recurring PMP Exam theme … “The Project Manager and Team should be pro-active, monitoring for risk events, looking for challenges and opportunities early-on in the process.”
楼主 美女约,不在线,有人找我吗?杜娟
来自 河北省
发帖 1129篇
PM币 16060
经验 5363点
Re:PMP考试的19个窍门(转) [回复于 2010/9/6]
quite useful
1楼 美女约,不在线,有人找我吗?nallyli
发帖 8篇
注册 2010/9/6
PM币 12
经验 15点
Re:PMP考试的19个窍门(转) [回复于 2010/9/7]
哈。我已经在我的博客里添加了
pmp是什么
项目管理越来越受青睐!
唯有不断学习,才能跟进时代进步
智鼎东方PMP认证培训
QQ:188269850 13621116468
http://www.pmp.wisdomoriental.com/
2楼 美女约,不在线,有人找我吗?aurapm
发帖 382篇
注册 2010/9/7
PM币 555
经验 560点
Re:PMP考试的19个窍门(转) [回复于 2010/9/9]
怎么是 English,看不懂啊
3楼 帅哥约,不在线,有人找我吗?zhangjianhong
来自 新疆维吾尔自治区
发帖 26篇
注册 2010/8/27
PM币 3
经验 64点
我正计划考呢,受用
4楼 美女约,不在线,有人找我吗?zhuly
发帖 135篇
注册 2010/8/5
PM币 88
经验 336点
Re:PMP考试的19个窍门(转) [回复于 2010/9/10]
The language of English is important
5楼 帅哥约,不在线,有人找我吗?黑白森林sls
发帖 54篇
注册 2010/9/2
PM币 21
经验 126点
收藏
6楼 帅哥约,不在线,有人找我吗?binsimon
注册 2010/9/10
经验 6点
Re:PMP考试的19个窍门(转) [回复于 2010/9/11]
有点吃力,看起来……
7楼 美女约,不在线,有人找我吗?nonohua
发帖 13篇
注册 2010/9/11
PM币 5
经验 20点
全是英文啊,看上去很有用,慢慢看,哈哈
8楼 帅哥约,不在线,有人找我吗?george1028
注册 2010/9/11
经验 12点
共20页  97 [ 第1页 第2页 第3页 第4页 第5页 第6页 第7页 第8页 -> ] 8:
