PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
请教三个时间方面的考题,并请解释原因,谢谢! [发表于 2003/9/4]
状态 开放帖 浏览量 1129
1.What is the technique of duration estimate where they analyze the allowances in activity sequence?
A: dependency diagram
B: gantt chart
C: critical path
D:pert
2.Which of the following parameters are affected by scheduling and allocating resources to multiple projects?
A:Resouse use and resource leveling
B: duration compression and simulation
C: activity lists and the WBS
D: schedule slippage and in-process inventory
3. You need to shorten the project completion date. Additional resources are not available and the project has low risk. when the dependencies are preferential. what is the best alternative?
A:cut resource from a task
B: Move resources from the preferential,what is the best alternative?
C:Remove tasks from the project
D:Make more tasks concurrent
以上三题的答案是C,D,D,请哪位大侠给解释一下,另外,the allowances in activity sequence(活动排序公差),in-process inventory(进行中存货),the dependencies are preferential(依赖关系是首选的)都是什么意思呀?
敬请指教,谢谢!
楼主 帅哥约,不在线,有人找我吗?springzy
发帖 14篇
注册 2003/8/18
PM币 140
经验 26点
Re:请教三个时间方面的考题,并请解释原因,谢谢! [回复于 2003/9/5]
为什么没人理我呀?呜呜呜……
1楼 帅哥约,不在线,有人找我吗?springzy
发帖 14篇
注册 2003/8/18
PM币 140
经验 26点
1. allowance能否理解为“松动”?
2. in-process,过程中,或者工序中
3. D,没有疑问。关于preferential dependency, 参考 PMBOK p69, 6.2.1.4,
2楼 帅哥约,不在线,有人找我吗?eexam
发帖 126篇
注册 2003/7/3
PM币 510
经验 26点
Re:请教三个时间方面的考题,并请解释原因,谢谢! [回复于 2003/9/6]
以后能否出中文题,郁闷
无事心静坐,有福方读书。
人生,是最重要的项目。
zhangqingjian@fawdde.com
18004090333
QQ:285858355
3楼 帅哥约,不在线,有人找我吗?zqjcep
发帖 6068篇
注册 2003/5/13
PM币 17711
经验 11695点
