PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
[讨论] please try      始发者    ELLEN [发表于 2003/2/17]
状态 开放帖 浏览量 2643
* 帖子主题 * 1 你是第 346 位浏览者
ELLEN
军衔: 一等兵
财产:
经验:
魅力:
来自: 不告诉你 :)
鉴定: 本功能已经被关闭
发帖: 93篇
注册: 2002-5-15
32. 2.17A scope change is one that—
项目范围变更是指[ ]
a. Modifies the project’s agreed-upon scope as defined by the WBS
在双方同意的基础上,修改WBS中规定的项目范围
b. Results in a change to all project baselines
能导致所有项目基线变动的变更
c. Requires adjustments to cost, time, quality, and other objectives
要求对成本、完工时间、质量和其他项目目标进行调整的变更
d. Results in a lesson learned
能让人吸取经验的变更
55. Thirty percent of the team has accepted an early retirement option effective immediately. What should the project manager do FIRST?
项目班子的百分之三十成员已接受将立即生效的提前退休选择。项目经理应首先做什么呢?[ ]
A. Revise the work breakdown structure
修订工作分解结构
B. Recruit team members
招聘项目班子成员
C. Implement the risk response
实施风险对策
D. Revise the linear responsibility chart
修订线性职责图表
85. 4.28 Cost accounts- 成本帐户—[ ]
a. Are charge accounts for personnel time management
是人事时间管理的经费帐户
b. Summarize project costs at level 2 of the WBS
在2级WBS水平上总结项目费用
c. Identify and track management reserves
界定并跟踪管理储备金
d. Represent the basic level at which project performance is measured and reported
代表测算和报告项目进展的基本水平
88. 4.35 Earned value should be used to estimate final project costs because it-
挣值应该被用来衡量最终的项目成本,因为它[ ]
a. Tests the "Official" position of the project manager against a statistically forecasted range of final
possibilities based on actual project performance
以项目实际执行的情况为依据,用预计最后出现的多种统计数据可能性来检验项目经理的“官方”位置。
b. Provides management with the final BAC, BCWS, and BCWP
给管理部门提供最终的BAC、BCWS和BCWP
c. Shows specific tasks in which cost overruns are expected to occur and, thus, focuses the
project manager's attention on critical tasks
显示出一些成本可能会超支的任务,从而让项目经理把注意力放在关键的任务上
d. Ensures that management reserve or contingency will not be needed
保证不需要管理储备金或应急储备金
122. 6.18 In both the weak and strong matrix organizational structures, the primary condition leading to conf1ict is—
在强和弱矩阵组织结构中,导致冲突的主要情况是:[ ]
a. Communication barriers 沟通障碍 b. Conflicting interests 相互冲突的利益
c. Need for consensus 需要统一意见 d. Ambiguous jurisdictions 管辖模糊
[ 本文发表于 2002年11月28日 9:19:10 ]
CG
军衔: PMU初级三星
财产:
经验:
魅力:
来自: 不告诉你 :)
鉴定: 本功能已经被关闭
发帖: 263篇
注册: 2002-2-5
1, A.
2, C
3,
4,
5, A
[ 本文发表于 2002年11月28日 10:12:29 ]
秋秋
军衔: 三等兵
财产:
经验:
魅力:
来自: 广西
鉴定: 本功能已经被关闭
发帖: 15篇
注册: 2002-11-28
好难哦。。。。。。。。。。。。。。。。。。
疾风知劲草.........................
[ 本文发表于 2002年11月28日 13:21:04 ]
find_ufo
军衔: PMU初级一星
财产:
经验:
魅力:
来自: 不告诉你 :)
鉴定: 本功能已经被关闭
发帖: 27篇
注册: 2002-8-28
1.a
2.c
3.没听说过这个词
4.c
5.d
[ 本文发表于 2002年11月29日 9:18:32 ]
peterliao
军衔: 三等兵
财产:
经验:
魅力:
来自: 北京市
鉴定: 本功能已经被关闭
发帖: 11篇
注册: 2002-9-5
同意find_ufo;
Let''s be friend!
[ 本文发表于 2002年12月3日 11:07:42 ]
vantasy
军衔: PMU初级三星
财产:
经验:
魅力:
来自: 不告诉你 :)
鉴定: 本功能已经被关闭
发帖: 66篇
注册: 2002-12-1
A C D(guessed) A A
[ 本文发表于 2002年12月3日 14:32:08 ]
sophiecn
军衔: PMU初级一星
财产:
经验:
魅力:
来自: 不告诉你 :)
鉴定: 本功能已经被关闭
发帖: 18篇
注册: 2002-11-8
1.a
2.c
3.d 设立成本帐户的目的是为了监督报告项目的执行情况。
4.c
5.d
[ 本文发表于 2002年12月3日 16:05:27 ]
badigoals
军衔: PMU初级二星
财产:
经验:
魅力:
来自: 不告诉你 :)
鉴定: 本功能已经被关闭
发帖: 24篇
注册: 2002-9-27
同意vantasy,也是猜的。
[ 本文发表于 2002年12月5日 11:23:14 ]
stella_peng
军衔: 无军衔
财产:
经验:
魅力:
来自: 不告诉你 :)
鉴定: 本功能已经被关闭
发帖: 14篇
注册: 2002-10-11
1.A 2.C 3.D 4.A 5.D
[ 本文发表于 2002年12月6日 11:15:16 ]
西风啊,请吹响你嘹亮的号角。。。。。。
楼主 帅哥约,不在线,有人找我吗?walkerch
来自 广东深圳
发帖 237篇
PM币 734
经验 477点
Re:[讨论] please try 始发者 ELLEN [回复于 2003/2/18]
我想让大家作几道题目是没有什么意义的。
重要的是你要把你觉得迷惑的地方或者想法说出来和大家讨论。
一切都将成为项目...
1楼 帅哥约,不在线,有人找我吗?Endeavor
发帖 18篇
注册 2003/2/18
PM币 152
