PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
2 questions [发表于 2003/2/18]
状态 开放帖 浏览量 2720
4. You have been assigned to manage a project in your organization to design develop and implement an ERP system. You will contract with and outside vendor to supply the ERP software. You realize that detailed planning for these types of real-time system is a prerequisite for success and form a team of key stakeholders to help prepare the plan. To assist in project plan development, you should use:
A. Make-or-buy analysis
B. Lesson learned and other historical information from previous projects
C. Benefit-cost analysis
D. The project management information system
Answer is D. 对于project plan development. B is input, D is tool.我该怎样识别问的是输入还是工具?
5. Because you recognize the importance of cost control, you identified a number of acceptable tolerances as part of your EVM system. Project change us inevitable, and some ‘unacceptable’ variances occurred. After each ‘unacceptable’ variance occurred, you did which one of the following first?
A. Updated the budget
B. Prepared a revised cost estimate
C. Adjusted the project plan
D. Documented the lesson learned
Answer is D.为什么不是A? 当有不可接受的变化发生,说明成本基线需要调整。B and D 都是output of cost control.
楼主 美女约,不在线,有人找我吗?jpgao
来自 beijing
发帖 0篇
注册 2007/12/8
Re:2 questions [回复于 2003/2/18]
对于问题2,我觉得这些事情本身都是对的,但是关键在于题目里面问的是First Action.我在参加培训的时候问过一些老师,这个纯粹只是PMI的一个观点.我想我们记住就是了.
一切都将成为项目...
1楼 帅哥约,不在线,有人找我吗?Endeavor
发帖 18篇
注册 2003/2/18
PM币 152
