One Risk question???????? [发表于 2003/12/9] 状态 开放帖 浏览量 1428 |
Project team A has been hired to manage a transportation project very similar to dozens of projects they've managed successfully in the past. The team has determined that the probability of achieving project objectives is 94%. The team has determined the size of contingency reserves that may be needed. These determinations are included in which process? A. Qualitative risk analysis B. Risk response planning C. Quantitative risk analysis D. Risk identification
Taping
发帖 25篇
注册 2003/3/27
Re:One Risk question????????
[回复于 2003/12/10]
B.
elixiang
发帖 74篇
注册 2003/8/23
PM币 471
[回复于 2003/12/10]
B is right see PMBOK ,contigency is determined at risk response process
horsetiger
发帖 17篇
注册 2003/4/10
PM币 119
[回复于 2003/12/10]
C probability of achieving project objectives and determined the size of contingency reserves is from C process.
ping
发帖 15篇
注册 2003/12/3
PM币 133
[回复于 2003/12/11]
对C有置疑。在实际工作中,不是所有的风险都需要定量分析。但所有的风险都需要在response中做应对。所以,B是正确答案
horsetiger
发帖 17篇
注册 2003/4/10
PM币 119
[回复于 2003/12/12]
C. 提干中提到的两点正好是风险定量分析的结果。
eexam
发帖 126篇
注册 2003/7/3
PM币 510
[回复于 2004/1/5]
PMBOK P144 contingency reserves amounts needed 是风险应对计划的输出
-------------------------------------------------------------------------------------------------------- PM阵营中永远的新兵……
Adam
发帖 418篇
PM币 439
[回复于 2004/1/5]
图在PMBOK P140,说明在P144 Contingency reserves amounts needed is one of Risk response Planning' outputs. B is correct!
-------------------------------------------------------------------------------------------------------- 地球是靠乐天派来推动的! http://davidwzp.blog.163.com
davidwzp
发帖 654篇
注册 2003/12/1
PM币 4767
[回复于 2004/1/5]
Confused: 一、probability is the output of quantitative risk analysis 11.4.3 Output from quantitative risk analysis 3.Probability of achieving the cost and time objectives The pobability of achieving the cost and time objectives under the current plan and the current knowladge of risksfacing the project can be estimated using quantitative risk. 二、contingency reserves is one of the content of risk reponse plan 11.5.3 Outputs form risk response planning 1.risk response plan:the risk reponse plan should be writen to the level of detail at which the action will be taken.It should include some or all of the following. …… Contingency plans and fallback plans
PMBOX
发帖 378篇
注册 2003/12/25
PM币 730
