PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
how is this problem to be solved. please help [发表于 2004/3/21]
状态 开放帖 浏览量 660
30 .a variance envelope has been established on a project. The envelope goes from +-30% in RD to +-5% during manufacturing. The reason for the change in thickness of the envelope is because:
1. the management reserve has been used up.
2. the accuracy of the estimates in manufacturing are worse than the estimates in R_D
3. tighter controls are always needed as a project begins to wind down.
4. of the personal desires of the project sponsor
5. none of the above
楼主 帅哥约,不在线,有人找我吗?phoenixwei
注册 2007/12/8
经验 31点
Re:how is this problem to be solved. please help [回复于 2004/3/21]
5
1楼 帅哥约,不在线,有人找我吗?土老冒
注册 2004/3/21
PM币 104
Re:how is this problem to be solved. please help [回复于 2004/3/22]
i think the answer should be no. 3, why do u choose no. 5.
2楼 帅哥约,不在线,有人找我吗?phoenixwei
注册 2007/12/8
经验 31点
BECAUSE:
the accuracy of the estimates in manufacturing are BETTER than the estimates in R_D
3楼 帅哥约,不在线,有人找我吗?土老冒
注册 2004/3/21
PM币 104
