PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
pmp试题求解,请说明原因!题后有答案! [发表于 2004/4/8]
状态 开放帖 浏览量 1980
1. You are managing a project that requires 25 full-time employees, of which 8 are from the mechanical engineering department. The person ultimately responsible for integrating the work within the mechanical engineering department is usually the: B
A. Lead mechanical engineer
B. Mechanical engineering department manager
C. Project office director
D. Project manager
你管理着一个需要25名职员的项目,其中8名来自机械工程部门。对于整合机械工程部门工作的最终的负责人通常是:
A. 首席机械工程师
B. 机械工程部门经理
C. 项目办主任
D. 项目经理
在此题中,project manager的责任是什么?
1. A process characteristic has a true (population) mean of 150 and a true (population) standard deviation of 20. A sample of 25 items is taken from this process. The standard deviation of the sample is: c
A. 0.2
B. 0.8
C. 4.0
D. 5.0
某过程特性的真实(总体)均值150和真实(总体)标准差20, 从这个过程中抽样25项。样品的标准差是:
A. 0.2
B. 0.8
C. 4.0
D. 5.0
17. Which of the following is not one of Crosby’s Four Absolutes of Quality? b
A. Quality means conformance to requirements
B. Quality is measured by the cost of conformance
C. Quality means that the performance standard is “zero defects”
D. Quality measured by the cost of nonconformance
下列哪一项不属于Crosby的质量的四条原则?
A. 质量意味着符合要求
B. 按照符合要求的成本来衡量质量
C. 质量意味着绩效标准是 "零缺陷"
D. 质量是根据不符合要求的成本来衡量
现代质量管理与古代区别?
If a company wants to measure up to the Malcolm Baldrige National Quality Award, which of the following criteria will they be evaluated to? c
A. ISO 9000
B. Quality policy
C. Strategic planning
D. ANSI standards
7. The objective of ___________________ is to provide the planned and systematic activities implemented within the quality system to gain confidence that the project will satisfy the relevant quality standards. B
A. Quality planning
B. ISO 9000
C. Quality assurance
D. Quality control
要做有计划的系统性活动,并在质量系统内完成,以便获得信赖,表明项目将满足适当的质量标准,这是下列哪一项的目标:
A. 质量规划
B. ISO 9000
C. 质量保证
D. 质量控制
Quality assurance的定义,答案是否错了
15. A process engineer on your project determines she must select a flowchart to solve a process flow problem. She would like to demonstrate the various causes and sub-causes that are creating the problem. .What flow chart would she most likely use? B
A. Pareto diagram
B. System diagram
C. Cost-benefit diagram
D. Fishbone Diagram
项目的工作技术工程师决定选用流程图来解决工作流程问题。她要展示说明导致问题的各种主要原因和次级原因。她最可能用什么流程图:
A. 巴雷托图
B. 系统图
C. 成本利益分析图
D. 鱼刺图
对System diagram影响不深,我选择D
19. In acceptance sampling, if the sample size is kept the same but the acceptance number is increased, which of the following will be true? C
A. Buyers’ risk will decrease
B. Procurement risk will decrease
C. Producers’ risk will decease
D. Consumers’ risk will decrease
在验收抽样中,如果样本数不变,但是抽样的合格数增加,下列哪一个是正确的:
A. 买家的风险减少
B. 采购风险减少
C. 生产者风险减少
D. 消费者风险减少
1.The risk of accepting a lot poor quality, in accepting sampling, is referred to as: B
A. High risk
B. Consumer’s risk
C. Producer’s risk
D. Type I error
进行抽样时,接受到很多差的样本,这被称为:
A. 高风险
B. 消费者风险
C. 生产者风险
D. 类型1错误
以上两题,Acceptance sampling的结果到底是影响producer 还是consumer,如何影响?
29. A process is considered out of statistical control when: A
A. There are special causes of varation
B. There are common causes of variation
C. There are random and non-assigned causes of variation
D. Statistical process control does not apply
流程会被考虑为超出统计控制,如果:
A. 差异有特别的原因
B. 差异有共同的原因
C. 差异是随机的和非计划的原因
D. 流程统计控制不适用
此题要考什么,不知道如何选择
1. A project manager estimates a project will take 14 weeks at a cost of $60,000. In signing the contract documents, the customer imposes a penalty for late completion of $2,000 per estimates that the maximum possible crashing of the project duration is 4 weeks, at an additional cost of $9,000. Assuming that the project manager is going to make the decision and that cost is the driving criteria for the project manager’s organization, what is the expected project cost? C
A. $69,000
B. $71,000
C. $70,000
D. $62,000
答案又几个版本,不知道时那个,如何计算的
2. In which project life cycle phase are the risks associated with project integration usually the smallest? B
A. Project initiation and approval
B. Project planning
C. Project execution
D. Project closeout
为什么不选a?
Risk----------------------------
If the minimum payoffs of four different strategies A1, A2, A3, and A4 are –10, 15, 0, and –20 respectively, which strategy would a project manager choose, using the “maximin” or Wald criteria (risk avoider)? c
A. Strategy A1
B. Strategy A2
C. Strategy A3
D. Strategy A4
如果四个不同的策略 A1 , A2 , A3 和 A4 的最小报酬分别是 -10,15,0, 和 -20, 用 “最小最大化”或Wald标准(避免风险), 项目经理会选择哪一个策略?
A. 策略 A1
B. 策略 A2
C. 策略 A3
D. 策略 A4
比太清楚the “maximin” 和“maximax”,碰到好几个题,不知如何计算,请详细解答
15. Which of the following is not an external, unpredictable risk? d
A. Changes in government regulations
B. Natural disasters
C. Vandalism
D. Inflation
下面哪一事项不是一个外部的不可预测的风险?
A. 政府管制的变化
B. 自然灾祸
C. 有意的破坏
D. 通货膨胀
我选择B,不知道是否错了
楼主 帅哥约,不在线,有人找我吗?gemini
发帖 45篇
注册 2004/3/19
PM币 195
经验 125点
Re:pmp试题求解,请说明原因!题后有答案! [回复于 2004/4/8]
晕,就会第一题。
1楼 美女约,不在线,有人找我吗?ever
发帖 63篇
注册 2003/10/14
PM币 579
经验 59点
Re:pmp试题求解,请说明原因!题后有答案! [回复于 2004/4/9]
第一题答案好像是A
2楼 帅哥约,不在线,有人找我吗?merymaid
发帖 16篇
注册 2004/3/21
PM币 54
Re:pmp试题求解,请说明原因!题后有答案! [回复于 2004/4/10]
1B,在此题中,project manager的责任是项目的管理而不是管理机械工程部门,对于整合机械工程部门工作的最终的负责人通常是机械工程部门经理(执行/运行组织负根本责任);
2C、根据概率统计知识中的中心极限定理"设X1,X2,X3,...,Xn是n个互相独立同分布的随机变量,假如其共同分布为正态分布
N(μ,σ2),则样本均值仍为正态分布,其均值不变仍为μ,而其方差缩小n倍"。即:σ2=20*20/25=16,故σ=4。〈以上解答不知对错,一开始我也不知道如何解答,后查阅全国质量专业技术人员职业资格考试专用教材(试行)的质量专业理论与实务(中级)——我国国家质量监督检验检疫总局质量司参考美国质量工程师的考试大纲组织编写的,才认为找到了答案,连清华大学出版刘广第主编的MBA工商管理硕士课程系列教材质量管理学书上都看不到任何线索。挺冷僻的,挺难的)。
3楼 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
3(17)、crosby是什么(请解答)?现代质量管理与古代区别?一般是指:工业化时代以前的质量管理被称为"操作者的质量管理",这时期的质量主要靠手工操作者本人依据自己的手艺和经验来把关,是手工业时期的原始质量管理,工业化时代的质量管理分3个阶段,质量检验阶段、统计质量控制阶段、全面质量管理阶段。
4楼 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
4应为C,ISO9000质量管理体系致力于实现组织的质量目标,达到持续的顾客满意,而质量保证致力于提供质量要求会得到满足的信任,是系统内部实施的有计划的、系统性的活动。
5楼 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
Re:pmp试题求解,请说明原因!题后有答案! [guojiayoung 修改于 2004/4/14]
5 B、 系统图(又称为树型图)是分析various causes and sub-causes的,与鱼刺图(因果分析图)结合使用,而 A巴雷托图是分析主要原因和次要(不是次级)原因的;鱼刺图(因果分析图)只反映了潜在的问题或结果与因素之间的联系,有助于制订处理问题的方法,但分不出来主—支关系。
6C. 生产者风险减小。
7B. 消费者风险,使用方风险β是质量坏的批被接收时使用方所承担的风险,生产方风险α是好的质量批被拒收时生产方所承担的风险。“以上两题,Acceptance sampling的结果到底是影响producer 还是consumer,如何影响?”,请看质量管理中的抽样检验理论。
8A. 差异有特别的原因,而不是C. 差异是随机的和非计划的原因。我认为主要是计划中的小概率事件 A process 发生了,超出了统计控制,只能认为是有特别的原因,而不是随机事件,是必然的小概率事件,在计划之内处于控制状态,而非计划之外,计划之外就是失控状态了,如果那么认为的话事实上是虚发信号,是控制图的两类错误之一。
6楼 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
1.这道题的考点项目质量管理中的职责分配,项目经理负责什么?技术经理负责什么?最终员工负责什么?知道以上内容,答案就明显了。(项目经理对整个项目负责)
2.的确有个公式来计算这样的题,不过我忘记了。
3.Crosby的质量成本是指非一致成本,而B是指一致性成本
4.同意,我也认为应选择C
5.因果图说明不了问题的级别,它只是问题的罗列。
6.似乎没什么说的,如果你有《项目管理:计划、进度和控制的系统方法》这本书,你可以进一步了解生产者风险、买家风险和消费者风险。
7.见上
8.这道题是考随机差异和特殊差异。随机差异是正常,而特殊差异是需要分析的。
9.这道题大家我发过,大家都不同意是C,但我的直觉让我认为C是对的,呵呵.
10.项目生命周期阶段里就没有A,既然题目说了哪个阶段,那就严格的看答案,项目启动就是启动没什么approval。
11.绝对值最小的
12.D没错,看看相关书籍,对外部不可预测风险都有详细列表。
7楼 帅哥约,不在线,有人找我吗?pmproad
发帖 63篇
注册 2004/3/2
PM币 201
Re:pmp试题求解,请说明原因!题后有答案! [回复于 2004/4/12]
非常感谢guojiayoung 、pmproad !
8楼 帅哥约,不在线,有人找我吗?gemini
发帖 45篇
注册 2004/3/19
PM币 195
经验 125点
