PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
2 questions [发表于 2003/2/24]
状态 开放帖 浏览量 1969
3. A supplier is working on a cost reimbursable contract when the buyer decides he would like to expand the scope of services and change to a fixed price contract. The supplier’s options include:
A. Completing the original work on a cost reimbursable basis and then negotiating a fixed price for the additional work
B. Completing the original work and rejecting the additional work
C. Negotiating a fixed price contract that includes all the work
D. All of the above
Is it the answer is A? and why others are wrong?
4. Metacommunication, paralinguistics, second-order messages, and the hidden dimension of communication all refer to:
A. Communication skills
B. Communication requirements
C. Ways to exercise to tolerance and compromise
D. Nonverbal communication
Answer is D. I don’t know the meaning of Metacommunication, paralinguistics, second-order messages, and the hidden dimension of communication
楼主 美女约,不在线,有人找我吗?jpgao
来自 beijing
发帖 0篇
注册 2007/12/8
Re:2 questions [回复于 2003/2/25]
3。A。
B的说法拒绝添加工作。根据项目成功的要求之一就是达到用户满意。B的后半部分明显会造成用户的不满。从这个角度上说项目就失败了。而作为项目经理应该保证项目的成功。所以B不对。
C。属于对于范围管理的工作。由于采用固定价格方式对于supplier来说是不利的,而且工作进行过程中的这种变更有可能导致rework。项目经理应该保护自己的团队的有效。因此,C的方法对自己是不公平的。所以不合适。
因为B、C不是合适的答案。所以D不对
1楼 帅哥约,不在线,有人找我吗?zcooker
发帖 73篇
PM币 309
经验 300点
