PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
几道范围的题,请说明选择理由! [发表于 2004/4/22]
状态 开放帖 浏览量 1227
1.In order to prevent or reduce the possibility of experiencing unplanned scope changes (sometimes known as scope creep) during project execution, the project manager should utilize a:
A. Initiation
B. Scope verification
C. Scope definition
D. Scope planning
在项目实施期间, 为了防止或减少出现非计划性的范围变更 (有时称之为范围蔓延) 的可能性, 项目经理应该利用:
A. 立项
B. 范围确证
C. 范围定义
D.范围规划
为了防止或减少出现非计划性的范围变更,不是应该定义scope statement 或WBS么?为什么选A
2. The three most common methods for structuring a work breakdown structure are:
A. Top down, bottom up, and organizational
B. Systems/subsystems, top down, and bottom up
C. Flow, life cycle, and organizational
D. Life cycle phasing, organizational, and discretionary
建立工作分解结构的三个最常用的方法是:
A. 自上而下法,自下而上法,有机组织法
B. 主次系统法,自上而下法,自下而上法
C. 流程法,生命周期法,有机组织法
D. 生命周期阶段法,有机组织法,权变法
3. A company convenes an estimating team to bid competitively on a project. Later, a negotiation team made up of different people is established to negotiate the final price. The project manager was not part of either team and is assigned after negotiations were completed and the contract was signed. A good project manager should mainly:
A. Disregard the assumptions/constraints used in estimating the job
B. Review the documents that authorize the project and define its objectives
C. Focus heavily on comparing the contractual statement of work with the proposal statement of work
D. Request a new project charter
某公司召集一个估算团队来对项目竞标报价。稍后,由不同的人组建了一个谈判团队来谈判决定最终价格。在完成了谈判并签订了合同后,才任命了项目经理,他并不是上述两个团队的成员。一个好的项目经理应该主要:
A. 不考虑工作估算所作的假定或条件限制
B. 了解检查项目授权和项目目标的文件.
C. 集中精力比较工作的合同要求说明书和工作建议说明书
D. 要求制定新的项目章程
AD首先排除,BC如何选择?
楼主 帅哥约,不在线,有人找我吗?gemini
发帖 45篇
注册 2004/3/19
PM币 195
经验 125点
Re:几道范围的题,请说明选择理由! [回复于 2004/4/22]
1,启动的输出是项目章程,所以选A,2,不会,3,我认为应该选B
我是一个PMP,我喜欢大家,有美女PMP我就更喜欢了。
shijie.wang@vip.163.com
1楼 帅哥约,不在线,有人找我吗?bmcwasj
发帖 60篇
注册 2004/4/12
PM币 199
经验 48点
Re:几道范围的题,请说明选择理由! [回复于 2004/4/23]
此题挺难,此题出处何在?
2楼 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
Re:几道范围的题,请说明选择理由! [回复于 2004/4/25]
第1题我选择的D,应该把Plan作为一个基准线
第2题用排除法选择C
第3题我选择B
PM阵营中永远的新兵……
3楼 帅哥约,不在线,有人找我吗?Adam
发帖 418篇
PM币 439
经验 650点
请各位大侠指点一下
PM阵营中永远的新兵……
4楼 帅哥约,不在线,有人找我吗?Adam
发帖 418篇
PM币 439
经验 650点
第1题选A,是不是可以这么理解:为了防止或减少出现非计划性的范围变更 (有时称之为范围蔓延),就是说要确认项目范围是什么,项目范围可用产品和服务的总和来描述;启动的输出中有project charter,其中包含产品描述和商业需求。启动已经确认了项目的存在和项目范围,而Scope planning 则是要逐步细化启动得出的项目范围,所以此处应该选A。
第2题我选C,不知道理由,算排除吧
第3题选B
各位指点,有没有权威的解释,盼望中。。。
5楼 帅哥约,不在线,有人找我吗?Patrick_YANG
发帖 122篇
注册 2004/4/25
PM币 258
经验 28点
Re:几道范围的题,请说明选择理由! [回复于 2004/4/27]
Patrick_YANG 在 2004-4-25 23:33:44 发表的内容
我觉得用项目计划是不是好一些啊,实施期间项目章程一般是用来证明自己有这个权力的
PM阵营中永远的新兵……
6楼 帅哥约,不在线,有人找我吗?Adam
发帖 418篇
PM币 439
经验 650点
1A、控制越早越好。“项目实施期间”是按项目生命周期说的,然后讲到“非计划性的范围变更”,在项目范围管理(按项目管理生命周期)中,最早的是启动(楼主翻译不准确,不是立项),而且是在计划之前,在计划或其之后的 范围确认、 范围定义、范围计划造成的都是计划性的范围变更。
7楼 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
3C、
A. 自上而下法,自下而上法,有机组织法:不可能自下而上,排除。
B. 主次系统法,自上而下法,自下而上法:同理,排除。
C. 流程法,生命周期法,有机组织法
D. 生命周期阶段法,有机组织法,权变法:权变也不是这个时候这个地方用的呀?排除。
8楼 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
