PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
4 questions [发表于 2003/2/28]
状态 开放帖 浏览量 1718
PMP sample test page—P117, 23, 24
1. Range estimating identifies all the following except:
A. Mathematical probability that a cost overrun will occur
B. Risks and opportunities ranked in order of bottom-line importance
C. The contingency required for a given level of confidence
D. The specific risk event impacting the estimate
Answer is D. I don’t know the meaning of this question. Why not select B?
2. A list of risk for additional study is an output of:
A. Risk identification
B. Qualitative risk analysis
C. Quantitative risk analysis
D. Risk response planning
Answer is D. I know the residual risk and second risk should be studied. But the one output of qualitative risk analysis: risks for additional analysis and management. Which one should I select in this position?
PMP sample test page—P159 No17
3. A manager has been given responsibility for a project that has the support from senior management. You found so many disagreement issues with the manager on what the deliverables should be. Your department was given tasks with providing some key deliverables for the project. What is the best solution?
A. Ask to be removed from the project
B. provide the manager what he needs
C. Inform your manager of your concerns to get their support
D. You discuss with the manager and try to make your advice understood until you agree a solution.
Answer is B. but I think D is right. If the PM is wrong with some tech and deliverable, should I give some suggestion first and abide him in the end?
4. in quality management
Is Infant mortality belongs to prevention cost or internal failure cost?
楼主 美女约,不在线,有人找我吗?jpgao
来自 beijing
发帖 0篇
注册 2007/12/8
