PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
PMP考试经验谈之三 [发表于 2003/3/14]
状态 开放帖 浏览量 700
Subject: A way (not necessary THE way) to pass the PMI Test
I did it! A few notes on the approach I took in case it helps and/or motivates any of yall to bite the bullet and take the test.
What I did was not the recommended way, but it coupled with prior PM experience turned out to be enough which is what counts (ie no gold plating needed just passing - bit of PM humor!).
What I Did to Prepare:
1) Sent my package to PMI to get permission to take the test before I studied anything or took any courses. (I work best under pressure). This gave me a three month deadline in which I had to take the test (ie the PMI OK to take the test expired in three months). The first available time that the Sylvan learning center I went to (East Brunswick) had was two months out.
2) Took the IBM 2 day IBM prep course. (Humbling experience in that it showed me how much I needed to learn but was an excellent way to pick up good study materials.)
2 months passed with virtually no studying on my part other than reading the PMBOK Q&A book (#SR23-8396-00 on pubs you should order this) out loud to my PMs over lunch (Thanks for listening and not throwing food!) and studying the Q&A book occasionally over lunch at my desk.
... 2 weeks to go before the test
3) Read each chapter in the PMBOK and took the practice test for each chapter. (I failed about half of the tests),
4) I read the PMBOK glossary.
5) I studied the right answers to the chapter tests and retook each test. ( I passed each one, missing only a couple but was convinced all I had proven was that I had a good short term memory since I had just read the test with the right answers).
6) I waited a day and then took the practice tests again (third time). (I passed each one but not as solidly as before).
7) The day before the test I took the lotus notes practice test that Beth Ann Cyrus and Annmarie sent me twice. The first time I failed, the second time I passed. (Again, I am thinking that all I am proving is that I have a good short term memory).
By now I was very tense convinced that I was not ready for the test and thinking what a waste of money that I had signed up before I was ready. Instead of staying up and studying some more, I went to bed early trying to sleep so I would be rested, not that I got much sleep!
8) I arrived at the testing center one hour early, and read the PMBOK glossary for a second time in the car.
9) Took the test and passed. Morale - we know more than we think we do, my prior PM experience helped out a lot, and studying to pass is very different than studying to get an "A" like we did in college years ago.
What I remember about the test:
1) The time allocation was more than sufficient, I took about half the time allocated. You can mark questions you want to come back to and review them later. I answered all, marked about 70 and reviewed those 70 after I was done. I changed maybe 4 answers, then I remembered the advise to go with first instincts so I stopped changing answers.
2) Lots of questions on earned value, but very little interpretive mostly straight calcs or identifying the right formula, one actual word problem where you had to pull out the data from the paragraph.
3) Lots of situational questions that described a project situation and asked what should the PM do.
4) Know the difference between quality assurance and quality control. Know the kinds of quality charts and tools
5) Not as much memorization on what are inputs, outputs and tools, but some of these.
6) The practice tests seemed harder than the real thing.
7) Lots of questions on leadership styles, what would be appropriate for a given situation.
8) Hitting the button to say I was done was actually harder than answering the questions!
Not sure if this will help any of you, but if I can pass it with the amount of prep that I put in, I know that you can pass it to if you make it a priority. Good luck and if I can help in any way let me know.
Jane Rees
Senior Business Area Manager, Pathmark Partnership
200 Milik Street
Mail Drop M-112
Carteret, NJ 07008
732-827-4366
T/L 479-4366
传播项目管理能力
楼主 帅哥约,不在线,有人找我吗?易风
发帖 4895篇
PM币 3273
经验 11319点
Re:PMP考试经验谈之三 [回复于 2009/9/15]
Thanks a lot
1楼 帅哥约,不在线,有人找我吗?lewishao
来自 重庆市
发帖 21篇
注册 2009/5/7
PM币 28
经验 28点
Re:PMP考试经验谈之三 [回复于 2009/10/27]
GOOD
2楼 帅哥约,不在线,有人找我吗?koko0110
发帖 253篇
注册 2006/8/18
PM币 123
经验 340点
