PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
紧急求救,以下几个问题不解? [发表于 2003/3/20]
状态 开放帖 浏览量 1963
48) Earned value is:
A. Actual cost of work performed.
B. Completed work value.
C. Budgeted cost of work performed.
D. Percent complete.
E. All except A
The given answer is E.But I Think is C or B,
maybe D is also right but A is definitely wrong,
it's AV.
69) CIP is:
A. Continuous improvement process
B. A sustained, gradual change
C. Includes constancy of purpose and commitment to quality as part of its focus
D. a and b
E. all of the above
The answer is E ,can someone explain why?
167) There is project with CPI of 0.81 and TCPI=1.00001 this project is
1) overbudget and cannot recover
2) underbudget
3) overbudget and early in its evolution
4) no interference can be made
I think the answer is 4.
168) As part of the quality audit, the scope statement is checked against the
work results to ensure the conformance to the customer requirements. The results
should be documented and used for:
A. Estimating future projects.
B. Changing the project scope.
C. Defining future project tasks.
E. Validating the quality process
The answer is b,why?
191) A project management professional can compare earned value performance data
to all of the following project management tools EXCEPT:
A. Critical path analysis.
B. Technical performance metrics.
C. Risk mitigation plans.
D. Forecasted final costs and schedule estimates
answer is D,why?
黑夜给了我黑色的眼睛
我却用它寻找光明
楼主 帅哥约,不在线,有人找我吗?embedsys
发帖 59篇
注册 2003/2/18
PM币 638
经验 507点
Re:紧急求救,以下几个问题不解? [回复于 2003/3/21]
It's difficult to understand .
1楼 帅哥约,不在线,有人找我吗?巽远
发帖 8篇
PM币 116
