PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
[讨论] 请解释一下这道题 [发表于 2004/8/12]
状态 开放帖 浏览量 488
You have been assigned as a project leader and must first review the statement of work provided by the customer. Although the answer can vary based on the industry, choose which one of the following are you most likely to overlook?
A. Data item deliverables
B. Customer-furnished equipment and facilities
C. Long-lead procurement items
D. Customer-imposed milestones
你被安排负责项目,首先必须检查评审客户提供的工作说明书。尽管不同的产业会有不同的答案,你最可能忽视下列哪项:
A. 工作成果数字化
B. 客户提供的设施
C. 长期重要的采购内容
D. 客户要求的工作里程碑
答案为A的合理解释是什么?
楼主 帅哥约,不在线,有人找我吗?slab
发帖 41篇
注册 2004/6/10
PM币 184
经验 45点
