PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
PMBOK2004草案版关于三重制约的论述 [发表于 2004/8/23]
状态 开放帖 浏览量 447
1.3 what is project management?
---------project managers offen talk of a triple constraint--------project scope,time and cost------in managing competing project requirements. project quality is affected by balancing these three factors (chapters 5 through 7). high quality projects deliver the required product or service within scope,on time and within budget. the relationship among these factors is such that if any one of the three factors changes, at least one other factor must change. project managers must also manage projects in response to uncertainty. project risk is an uncertain event or condition that, if it occurs, has a positive or negative effect on at least one project objective.
楼主 帅哥约,不在线,有人找我吗?chinastar
Re:PMBOK2004草案版关于三重制约的论述 [回复于 2004/9/5]
bigpond在8.26发表的:
参考译文:
什么是项目管理?
--------项目经理经常谈到三重制约--------项目范围,时间和成本--------这是管理竞争项目的要求。 项目质量受上述三者平衡的影响(第5到7章)。 高质量的项目移交要求产品或者服务在范围之内,按时并不超预算。 上述因素之间的关系是这样的,如果三者之一发生变化,至少另外一个因素要跟着发生变化。 项目经理还必须回应不确定性来管理项目。 项目风险是不确定的事件或者条件,如果其发生的话,将对至少一个项目目标产生正面或者负面的影响
1楼 帅哥约,不在线,有人找我吗?chinastar
