PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
[讨论] PMP备考经典练习10 [发表于 2004/8/28]
状态 开放帖 浏览量 1208
10.The project sponsor has approached you with a dilemma. The CEO announced at the annual stockholders meeting that the project you
are managing will be completed by the end of this year. The problem is that this is six months prior to the scheduled completion date.
It’s too late to go back and correct her mistake, and stockholders are expecting implementation by the announced date. You must speed up the delivery date of this project. Your primary constraint before
this occurred was the budget. What actions can you take to help speed
up the project?
A. Hire more resources to get the work completed faster.
B. Ask for more money so that you can contract out one of the phases you had planned to do with in-house resources.
C. Utilize negotiation and influencing skills to convince the project
sponsor to speak with the CEO and make a correction to her announcement.
D. Examine the project plan to see if there are any phases that can
be fast tracked, and then revise the project plan to reflect the
compression of the schedule.
项目出资人使你陷入了一个两难的处境。CEO已经在年度股东大会上宣布你正在进行的项目将在本年年底完成。问题是,这样就要求要比原来进度规定的完成日期提前六个月完成。返回去再去纠正她的错误已经来不及了,而且股东们也正期待着项目在CEO宣布的日期完工呢。你必须提前这个项目的交付日期。这件事发生之前,你的主要制约因素就是预算。你可以采取什么措施来加速项目的完成。
A. 采用更多的资源以使工作更快地完成。
B. 申请更多的资金以使你可以将原定由内部资源完成的项目阶段改为外部完成。
C. 利用谈判和影响技巧说服项目出资人去劝说CEO并对她的宣告做出修正。
D. 检查项目计划看看是否有能够快速跟进的阶段,如果有就修改计划来反映进度压缩。
楼主 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
Re:[讨论] PMP备考经典练习10 [回复于 2004/8/29]
D
1楼 美女约,不在线,有人找我吗?莉莉
发帖 116篇
注册 2004/8/15
PM币 256
经验 3点
Re:[讨论] PMP备考经典练习10 [回复于 2004/8/30]
猜 b
2楼 帅哥约,不在线,有人找我吗?eveningstar
发帖 1689篇
注册 2004/4/7
PM币 1361
经验 162点
B
如果我只剩下一分钱
我要把它
抛向蓝天
去买
一份快乐
然后
与你分享
3楼 美女约,不在线,有人找我吗?shsjsj
发帖 24篇
注册 2004/8/20
PM币 96
经验 59点
eveningstar 、shsjsj :说说为什么?
我认为是:D。
4楼 帅哥约,不在线,有人找我吗?guojiayoung
发帖 2211篇
注册 2004/4/9
PM币 1893
经验 496点
Re:[讨论] PMP备考经典练习10 [回复于 2004/9/1]
答案是什么?
只是感觉,错了就不用说为什么了:)
5楼 帅哥约,不在线,有人找我吗?eveningstar
发帖 1689篇
注册 2004/4/7
PM币 1361
经验 162点
我选D
谁来公布和解释一下正确答案呢
说醒时只缘醉...
MSN : lavenderhyh@hotmail.com
主页: http://lavenderhyh.blogchina.com
6楼 美女约,不在线,有人找我吗?lavender_hyh
发帖 966篇
注册 2004/7/15
PM币 5651
经验 2741点
认为应该是D,
最大的制约是预算,则“更多的资源”和“更多的资金”是不可获取的,首先排除C,
7楼 帅哥约,不在线,有人找我吗?sign
发帖 15篇
注册 2004/9/1
PM币 119
Re:[讨论] PMP备考经典练习10 [回复于 2004/9/2]
D。因为有限制Your primary constraint before
8楼 帅哥约,不在线,有人找我吗?rickluxe
发帖 683篇
注册 2003/8/1
PM币 2285
经验 668点
