PMP2002
登录:2018/9/29
次数:3838
发帖:3424
ljdy44
登录:2015/11/14
次数:227
注册:2005/6/29
发帖:171
问题8 [发表于 2004/9/6]
状态 开放帖 浏览量 677
You are managing an internal R&D project. the initial test result are very poor.
your are afraid your manager might cancel the project, and this could reflect
poorly upon you. verification testing could be done quickly and inexpensively.
you might:
a be the first to recommend canceling the project
b inform management about the result and wait for a response
c inform management immediately and recommend retesting for verification
d withhold the information from management until you perform additional tests to
verify the initial result.
楼主 帅哥约,不在线,有人找我吗?eveningstar
发帖 1689篇
注册 2004/4/7
PM币 1361
经验 162点
Re:问题8 [回复于 2004/9/6]
c
1楼 帅哥约,不在线,有人找我吗?jamesqi
发帖 75篇
注册 2004/6/30
PM币 177
经验 28点
d
2楼 美女约,不在线,有人找我吗?julietpb
发帖 0篇
注册 2007/12/8
Re:问题8 [回复于 2004/9/7]
这种题最难,不知道老美怎么想
3楼 帅哥约,不在线,有人找我吗?eveningstar
发帖 1689篇
注册 2004/4/7
PM币 1361
经验 162点
老美讲究诚实,所以我选c,理由是让上级知道发生什么,并且提供建议.d好象有瞒的成分.
4楼 帅哥约,不在线,有人找我吗?jamesqi
发帖 75篇
注册 2004/6/30
PM币 177
经验 28点
Re:问题8 [回复于 2004/9/8]
答案给的是 d
5楼 帅哥约,不在线,有人找我吗?eveningstar
发帖 1689篇
注册 2004/4/7
PM币 1361
经验 162点
